ABS Fluid
My girlfriend has a 95 accord ex. The problem is her ABS fluid leaks, it takes about a weak or so for it to go down where the ABS light comes on. I was wondering where the best place to check where the leak is coming from. The car makes no noise and can break fine. Thanks in advance
Please use the search feature and after you have read the Accord Forum Guidelines, you can read this thread and fix your ABS problem...
https://honda-tech.com/zerothread?id=241713
