Going back to dino oil at 102k?
Old Jan 6, 2003 | 04:33 AM
speedymon's Avatar
Default Going back to dino oil at 102k?
Is it safe to switch to Castrol GTX? I've got a 102k gsr motor thats seen nothing but Mobil1 Syn. It's also a turbod motor and i dont' have any abnormal oil loss. What's your opinion?
Old Jan 6, 2003 | 11:53 AM
speedymon's Avatar
Default Re: Going back to dino oil at 102k? (speedymon)
Anyone?
Old Jan 6, 2003 | 11:57 AM
B2FiNiTY's Avatar
Are you doing this to save money? I don't see why not.
Old Jan 6, 2003 | 12:02 PM
speedymon's Avatar
Default Re: Going back to dino oil at 102k? (B2FiNiTY)
For that reason and after reading the great oil thread, i decided no reason to use synthetic. I'm changing it often anyways and i seldon push my car hard so why not.
Old Jan 6, 2003 | 12:45 PM
Dirt's Avatar
You'll be fine.
Old Jan 6, 2003 | 08:16 PM
B U N M A N G O's Avatar
Default Re: Going back to dino oil at 102k? (BrewCityR)
I switched back to conventional oil on my last oilchange... I had some maintenance work done at 96k (filled back up with Mobil 1 Syn) and by 96.5k I was down a quart, and by 97k yet another quart, so I decided to just flush it and go back to conventional. So far (500mi later) it seems like my oil consumption has dropped significantly.
Old Jan 6, 2003 | 08:27 PM
itr1244's Avatar
Default Re: Going back to dino oil at 102k? (bunmango)
what's wrong with Mobil 1
Old Jan 6, 2003 | 09:01 PM
Volcom's Avatar
Default Re: Going back to dino oil at 102k? (itr1244)
It's expensive! Just change over to GTX. I did it at 120K and no problems here.
Old Jan 7, 2003 | 03:07 AM
speedymon's Avatar
Default Re: Going back to dino oil at 102k? (Volcom)
Well i guess i'll be alright. Should i flush it with anything first? Like some dino/syn blend oil first?
Old Jan 7, 2003 | 08:06 AM
Volcom's Avatar
I never did. You might if you are worried about. I think they sell oil flush stuff that you put in and drive around for 100 miles or so and then drain, and fill with your dino oil.
Old Jan 17, 2003 | 01:55 PM
speedymon's Avatar
Well i switched back from synthetic oil and so far no problems. I let the oil drip out for a long time. In the end about 3.7 liters had dripped out. So far so good.
HA0LEFIED
Honda Civic (2006 - 2015)
Nov 18, 2007 08:23 PM
ex_ricer
May 18, 2007 11:36 AM
JTTeG_X
Nov 1, 2005 08:41 PM
winlo408
Sep 2, 2004 10:59 PM
V-Thang
Acura TL, RL & ZDX
Jan 9, 2004 11:04 AM
