Anyone relocate their battery to the trunk??
Old Jan 5, 2003 | 07:29 PM
AndyD's Avatar
Default Anyone relocate their battery to the trunk??
Hi guys, anyone do this yet?? Particualrly in 4th Gens. but any will do.
I am thinking about getting a small light weight battery and mount it into the trunk. I am hoping it will fit in the wheel well but if not I want to put it on the right side of the car in the trunk.
Any ideas??? Advice??
Old Jan 5, 2003 | 08:03 PM
sslude's Avatar
Default Re: Anyone relocate their battery to the trunk?? (AndyD)
did you want to learn how to? i thing they have it at ntpog.com or .net. or did you want to know why they do it?
Old Jan 5, 2003 | 08:05 PM
blacklude's Avatar
I think http://www.summitracing.com offers trunk relocation kits.
Old Jan 6, 2003 | 06:51 AM
BoostedH23a1's Avatar
Default Re: Anyone relocate their battery to the trunk?? (Boosted F22)
i got s summit battery relocation kit for 50 dollars shipped. comes with everything u need.
Old Jan 6, 2003 | 07:03 AM
AndyD's Avatar
AWESOME. Can you psot the details how you did it?? I really want to do this. I am going to get a lightweigth battery and mount it on the pass. side in the trunk.
I am wondering how I can best run the cables through the car and to the starter.
Thanks
Old Jan 6, 2003 | 07:14 AM
rjr162's Avatar
Thanks
Firewall. You might have to punch your own hole, and get a good graumit (?) so the wire won't rub and short out. As for a good battery, you could go with a Mini-Red Cap optima, they are fairly small (about the same size as a 98 civic's battery) but has over 900 CCA.
Old Jan 6, 2003 | 07:15 AM
AndyD's Avatar
Default Re: Anyone relocate their battery to the trunk?? (PreloodDude)
i did mine for about $2.
what i used:
- 6 gauge copper cable from Home Depot
- sandpaper (for a good ground on chassis)
easy. DIY. I wouldn't waste money on a kit, imo.
NICE. You have any pics of it??
Old Jan 6, 2003 | 08:44 AM
AndyD's Avatar
I ran mine throught the front passenger fender instead of the firewall. Ive heard using house wire is bad. I tried it and had bad luck with it, plus its a bitch to bend.
I just sanded, and grounded to a strong point in the chassis, then ran the wire under the carpet. Make sure you use good connectors to the starter that wont get loose. Last thing you want is a bare cable grounding out. (i looked under the hood one day and this happened. bare wire was hanging like 1mm from the chassis. I got lucky
I see.
So when you ran it through the pass. side fender well is there a existing hole that you can run the wire through or do you have to drill a hole???
Old Jan 6, 2003 | 09:21 AM
rjr162's Avatar
Yes, it's solid wire, you want stranded. DC flows over wires, so the more surface area, the more power transfer (amps). With house wire, it's solid, so you get very very small surface area. AC goes thru wires, so solid wire is fine for those applicatins.
BTW> when you say in via the fender, you don't mean you looped it by the door do you? If so, DO NOT do this, as it's very poor practice and opening and closing the door can eventually take away the insulation.
[Modified by rjr162, 6:23 PM 1/6/2003]
Old Jan 6, 2003 | 09:31 AM
Firedrake's Avatar
Default Re: Anyone relocate their battery to the trunk?? (rjr162)
There is a guy on EBAY that sells battery relocation kits that are the BEST for the money.....he's out in Las Vegas if I remember correctly, that's where I got mine for like 40 shipped or something. He used welding wire for the cables.....
I put mine in my trunk also, let me know if you want pics of stuff.....
Brian
Old Jan 6, 2003 | 01:24 PM
SilverLudeSi's Avatar
New User
I did mine with a summit box and relocation kit (0 gauge cable).
Old Jan 6, 2003 | 01:40 PM
AndyD's Avatar
AndyD - if you lift up the carpet near the ECU, you'll see a wire grommet thing. I just poked a hole in this and coaxed the wire to go through the fender. It'll come out in an existing hole near where the battery already is. IN the picture below, you'll see the two IC pipes on the passenger side. The hole is right about there.
AWESOME!! Thanks guys. I didn't realize so many of you actually did this. SilverLudeSi, thanks for the pics. REALLY helped.
This is why I love this site.
When I put my H22 in I am going to run the cables to the trunk and also take out my whole AC components.
[Modified by AndyD, 10:42 PM 1/6/2003]
Old Jan 7, 2003 | 05:11 PM
BlueShadow's Avatar
Does anyone know the part number or what search word I put in on wimmitracing to find the battery relocation kit?
thanks
EDIT: nevermind, I found it after going through 9 pages of crap.
Summit Racing Equipment pn# SUM-G1200A
[Modified by BlueShadow, 6:16 PM 1/7/2003]
Old Jan 8, 2003 | 02:58 AM
Boostless97Lude
Guest
Posts: n/a
nope, still under the hood, just modified
Old Jan 8, 2003 | 12:26 PM
osuPrelude's Avatar
Default Re: Anyone relocate their battery to the trunk?? (Boosted97Lude)
Now I know this helps with acheiving neutral weight distrobution, but honestly how much? Does it even make the f/r ratio change 1%? It would be interesting to test, hmmm.
Old Jan 8, 2003 | 01:40 PM
BlueShadow's Avatar
Default Re: Anyone relocate their battery to the trunk?? (osuPrelude)
Probably the main reason us turbo guys are doing it is to have room for a filter that is farther away from the compressor. That's the reason I'm doing it anyways.
Old Jan 8, 2003 | 01:41 PM
F the weight ratio. i had to do it to make room for turbo.. less weigh on the front wheels means less traction..
Old Jan 8, 2003 | 07:14 PM
slipslap's Avatar
Default Re: Anyone relocate their battery to the trunk?? (BoostedH23a1)
i did mine my self for 15 bucks. buy some 2 gauge or 4 u can get away with 4. theres a hole in you trunk right there on right. remove gromet and run wires down there. you can ground it on that tow hook. i attached my wire to fire wall **** under there and ran to front. then go to stereo shop and get a power distribution block( i had 1 from old stereo) and mount it right there to fender well right under fuse box. then hook wire from strarter in it and the wire from fuse box. and there it is. if your in a 3rd gen. now you can put in you CAI.
Old Jan 9, 2003 | 02:41 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: Anyone relocate their battery to the trunk?? (slipslap)
i'd lie to know where the hell you got 2 guage cable long enough to reach from the enigne bay to the trunk for under 15 bucks
Old Jan 9, 2003 | 05:34 AM
Daemione's Avatar
www.knuconceptz.com has 1/0 gauge for $2.25 a foot.
Old Jan 9, 2003 | 06:18 AM
slipslap's Avatar
i've been using 4 gauge, for a while now and no problems. go to home depot. its the same **** as stereo shop, just different color and it ranges from .31-.75 a foot. and i used 15 feet in a 3rd gen and it was enough to do what i needed.
jdmdohcek98
Aug 24, 2011 05:30 PM
sleepinbeauTEG
Dec 11, 2004 10:07 AM
spontaneous ep3
16
Sep 7, 2004 09:04 PM
GARBhatch.
Oct 7, 2002 11:08 AM
Stinkalope
May 31, 2001 05:32 AM
