FS: Hondata S200 w/ boost + Chipped 95 LS ECU
Old Jan 5, 2003 | 03:02 PM
Foozball26's Avatar
Default FS: Hondata S200 w/ boost + Chipped 95 LS ECU
Hey guys as the title states got this little package for sale.
I also have a OBD 2 > OBD 1 Conversion Harness for sale
Asking $550 for the Hondata and ECU together
Asking $100 for the Conversion Harness if bought with the Hondata and ECU
ECU was Chipped by Jotech and the Conversion Harness was made by Jason Kohler.
Old Jan 5, 2003 | 03:37 PM
kamaleon's Avatar
Default Re: FS: Hondata S200 w/ boost + Chipped 95 LS ECU (foozball-26)
can u use that ecu with a d16? ..
ultimatelly i want to run hondata on my boo sted d16.
Old Jan 5, 2003 | 04:36 PM
Foozball26's Avatar
Default Re: FS: Hondata S200 w/ boost + Chipped 95 LS ECU (kamaleon)
Theres a yes and no answer to that question, if you have a non-vtec D16 then yes it will work (how it will run is a toss up) if your D16 is Vtec im not sure since the Integra LS was a non-vtec engine. I can find out for you tommorow for sure.
Old Jan 5, 2003 | 06:46 PM
TurbothisLS's Avatar
where in dallas are u located?
willing to work out a trade?
Old Jan 5, 2003 | 07:12 PM
kamaleon's Avatar
Default Re: FS: Hondata S200 w/ boost + Chipped 95 LS ECU (TurbothisLS)
mine is vtec
how much are u willign to let that s200 go?!
Old Jan 6, 2003 | 01:16 AM
Foozball26's Avatar
Im in the frankford and tollway area but am frequently in richardson and garland.
Depends on what you have to trade shoot me and im of what you have.
Old Jan 6, 2003 | 01:19 AM
Foozball26's Avatar
mine is vtec
ok, it wouldnt control vtec then but thats the only difference. I had only set aside $100 for the ecu since most people probably wouldnt need it so for just the hondata $450
Old Jan 6, 2003 | 12:22 PM
wickedxboi's Avatar
i may be interested...what else will i need to complete this? i have a 99 ls. do you have a base map to work with?
Old Jan 6, 2003 | 07:40 PM
Foozball26's Avatar
Default Re: FS: Hondata S200 w/ boost + Chipped 95 LS ECU (wickedxboi)
Well you would need a different harness to convert to obd 1 but other than that you are set. I have a base map for turbo LS w/ 75lb injectors w/ a 3 bar map so it may or may not work depening on what you have.
Old Jan 7, 2003 | 10:16 AM
kamaleon's Avatar
if ur willign to part out.. le tme knwo how much u want for the s200 w/boost
Old Jan 7, 2003 | 12:15 PM
Foozball26's Avatar
ok ill let you know I wanna see if i can get the whole system sold but if not ill get back to ya.
Old Jan 7, 2003 | 12:28 PM
kamaleon's Avatar
ok, let me know
Old Jan 7, 2003 | 11:03 PM
Jdm_Rice_Monster's Avatar
isnt that setup only 495 from hondata, I am still tring to figure out what all needs to be done to run it. When you pay the 495 for the s200 with boost what other costs are entailed.
Old Jan 8, 2003 | 12:23 AM
Foozball26's Avatar
Default Re: FS: Hondata S200 w/ boost + Chipped 95 LS ECU (JdmRiceMonster)
you still have to get someone to chip your ECU if you cannot do it yourself. And if you are OBD2 then you must buy a conversion harness. Other than that just tune it thats it.
Old Jan 8, 2003 | 12:30 AM
how much was it just to get it chipped, I can get honda brand new for a little over 400 for the s200 with boost, but I am not sure how much it cost for the chipping or socketing that has to be done. Some one help me out on this.
Old Jan 8, 2003 | 09:03 AM
TurboTegB18c's Avatar
Chipping an ecu for hondata is usually around $50. Paul
Old Jan 8, 2003 | 09:17 AM
kamaleon's Avatar
Default Re: FS: Hondata S200 w/ boost + Chipped 95 LS ECU (TurboD16Z6)
JdmRiceMonster were do u get that s200 for 4 bills? new
Old Jan 8, 2003 | 01:30 PM
I have a wholesale account and I get usually 15-20 off msrp.
Old Jan 8, 2003 | 03:50 PM
kamaleon's Avatar
whats the lowes u can get it? i want to buy one
Old Jan 8, 2003 | 10:33 PM
like 20 percent off, so 495 minus 20 percent,
Old Feb 25, 2003 | 09:15 AM
integranator's Avatar
you've got a pm
Old Feb 25, 2003 | 09:22 AM
Foozball26's Avatar
************************ITEMS HAVE BEEN SOLD***********************
Punker1234
Jan 14, 2006 01:10 PM
JunIntegra
Nov 10, 2003 09:05 AM
StinkyTofu
Oct 12, 2003 08:16 PM
integranator
Mar 2, 2003 09:45 AM
sydag5
Dec 22, 2002 09:00 AM
