Those who installed their KYB AGX's I need your help
Old Jan 5, 2003 | 06:51 AM
Just2Fast's Avatar
Default Those who installed their KYB AGX's I need your help
The KYB Agx's come with a round washer that is put on after the bumpstop. The stock shocks come with a circular silver washer that is placed on top of the bumpstop.
Do I use both the circular washer and the peice suplied by KYB?
Or Do I just use the peice supplied by KYB?
Old Jan 5, 2003 | 08:19 AM
Just2Fast's Avatar
Default Re: Those who installed their KYB AGX's I need your help (Just2Fast)
Anyone ?
Old Jan 5, 2003 | 08:32 AM
PainfulTeg's Avatar
i used everything they gave me and it came out fine, it's the fuggin LCA bolts that are the scary part....
Old Jan 5, 2003 | 08:44 AM
Just2Fast's Avatar
Default Re: Those who installed their KYB AGX's I need your help (PainfulTeg)
So the stock washer that came with the car wasnt used?
Old Jan 5, 2003 | 09:09 AM
The-LS's Avatar
I didn't used the stock washer since it wasn't in the instructions to do so.
Old Jan 5, 2003 | 09:38 AM
trustbuddy's Avatar
Default Re: Those who installed their KYB AGX's I need your help (RayRay000)
try to use the original washer that came with the oem shock...if the washer is damaged in any way, then use the washer supplied by kyb.......it's always better to go with oem even with bolts, lugs, nuts...etc..
[Modified by trustbuddy, 6:39 PM 1/5/2003]
Old Jan 5, 2003 | 10:45 AM
Acronym's Avatar
Default Re: Those who installed their KYB AGX's I need your help (trustbuddy)
I used KYB washer but of course kept stock 4 back up! Every OEM part i keep!
Old Jan 5, 2003 | 12:11 PM
ebelp's Avatar
Default Re: Those who installed their KYB AGX's I need your help (Acronym)
Yeah, use one washer or the other. Don't use both.
Old Jan 5, 2003 | 12:55 PM
Lou_Cypher's Avatar
Default Re: Those who installed their KYB AGX's I need your help (ebelp)
my mechanic put mine on last week, he took off the huge silver washer that came with the stocks and used them INSTEAD of the ones that came with the KYB's, I asked him why and he said "because there's a chance that those little ones that come with the KYB's could go through at a later date"; it made sense to me
Old Jan 5, 2003 | 01:16 PM
Windows 95's Avatar
Default Re: Those who installed their KYB AGX's I need your help (Lou_Cypher)
If I can remember right, the OEM big round washer on the strut shaft and the little gold one supplied by KYB are there to hold up the cowbell dust cover. It doesn't matter whice one you use, their function isn't very critical to the shock, and the KYB one isn't any crappier than the OEM one. a washer is a washer ya know.. I used the KYB one because it said to in the instructions, but like I said, it doesn't matter which one you use.
Old Jan 5, 2003 | 05:34 PM
The-LS's Avatar
Default Re: Those who installed their KYB AGX's I need your help (Windows 95)
I don't know about anyone else's AGXs, but if were talking about the same "collar" supplied by KYB than I don't see how you would or could use a regular washer to REPLACE it. I can understand if you added the stock washer on top of it, but without it I think its not safe since the collar that comes with the AGX is shaped to fit perfectly on to the TAPERED shaft.
Atomic1
Suspension & Brakes
Jun 5, 2011 05:05 AM
thermostate82
Feb 8, 2009 02:59 PM
Fooman
Apr 16, 2002 05:14 PM
