Your valve covers...
I'm just curious to see what the majority of you guys think on this subject... do you like your valve covers cut to expose the cam gears or left stock? Which do you think looks better? Let me know, leave some comments.
Scott
Scott
This is what he means by cut-- his work as well.
And i personally, would think cut is the way to go, from him at least. If i had hte money, I would definately go with his work.
man.
man.
The only thing I'd be worried about it how much dirt and debris would get on the timing belt. Seems like that should be a well guarded part of the engine.
Maybe he could cut the cover just where the cam gears would need to be seen at. Like, half circle, so that the gears would be able to be seen, but the timing belt would not be shown. I'll find a pic.
Yeah, that looks nice but it takes a little more work, so in order to get that it would cost more time which equals more money... personally I've never actually tried cutting like that. But on to the procedure question, I simply cut off the section at a certain point, make sure its even, sand it to smooth edges and give it a rounded off look, then I polish it up to blend with the rest of the valve cover.
Scott
Scott
is that a turbo h22 in a DA???
btw, SM, what do you use to cut the valve covers?
[Modified by ebelp, 10:52 PM 1/5/2003]
Stock only because I don't know who or how to get it cut. I'd be too afraid the shop would hack it up...
len
Err...I seemed to missed the whole point of most of you guys cutting the valve cover. Are you cutting just for looks or are you cutting for a purpose?
I'm going to cut mine when I get more aggressive mods on my car and cam gears that are tunable. I also like it cut because you can keep a close eye on the condition of your timing belt.
But cutting it just for the look...
len
len
The whole laser cutting thing seems to be overkill to me, all you need is the stationary saw and some machine know how, then some sanding materials and polishing materials. If I lined up that picture above with one that was laser cut in the same way, I don't think you could tell them apart.
Although mind you, laser cutting is the only way to go when trying to do things such as the half moon look like above, etc.
Scott
Scott
i cut half circles in the cover and the middle cover, makes a perfect circle. h22 hith a nice jig saw blade and a dremel tool to sand it smooth looks damn clean i think. not easy doing that to a type s cover.
ya i think this should be dependent on whether or not you have adjustable cam gears. otherwise that would be uber rice lol
just use a dremel and cut the half circles
raverx3m
20
Jul 23, 2010 08:30 PM
