Head differences between F20B and h22a head... same or not..
Old Jan 4, 2003 | 08:50 PM
HotWheelz's Avatar
Default Head differences between F20B and h22a head... same or not..
wondering if different valves, how the port design is in them, if the rocker arm assembly is different.. head only, i know the intake manifold is different and slightly polished but wondering for f20b head -PCB- code...
thanx... i allready know it comes with type-s camshafts and springs and retainers.. mostly wondering about the casting information..
Old Dec 29, 2003 | 07:46 PM
ALLMOTORJ's Avatar
Default Re: Head differences between F20B and h22a head... same or not.. (HotWheelz)
any one? I heard the valves are smaller because of the displacement.
Old Jan 6, 2004 | 02:12 PM
ALLMOTORJ's Avatar
Default Re: Head differences between F20B and h22a head... same or not.. (4gotpasswordAGAIN)
smaller combustion chamber???
Old Jan 17, 2004 | 04:15 PM
machine4321's Avatar
it is a type S head....
so all is the same except for the cams and such
Old Jan 19, 2004 | 03:04 PM
k_spek's Avatar
Default Re: (machine4321)
People are sayin in the all motor forum that the f20b head is the same as a type s head. Same cams and stock porting as the type s. Does anyone know the stamp number on the head? Is it p13?
Old Jan 21, 2004 | 11:55 AM
ALLMOTORJ's Avatar
Default Re: (laugHin22CX)
The F20b head is stamped PCD or something like that, I know its not P13 though... Is a Type-S head stamped P13???
Old Feb 16, 2004 | 08:01 PM
JDogg's Avatar
Default Re: (4gotpasswordAGAIN)
its stamped pcb
Old Feb 16, 2004 | 09:36 PM
Eddiebx's Avatar
i;m sure the combustion chambers are slightly smaller considerign its got a 85mm bore if i remember correctly.
Old Feb 16, 2004 | 09:41 PM
JDogg's Avatar
Default Re: (Eddiebx)
ill have mine apart soon enough.... ill have pics and measurements and stuff
Old Feb 17, 2004 | 09:10 AM
PirateMcFred's Avatar
Default Re: (JDogg)
"P5P" is on the H22 Type-S head/block/pistons Not "P13" that is your typical H22...
Old Feb 17, 2004 | 01:47 PM
satan_srv's Avatar
Default Re: (JDogg)
as discussed in the other thread the Head gets the PCB label because it's an 85mm bore however the chamber is still 54cc just like the H22a thus it's reasonable to assume they just ported the chamber to get the same volume.
Old Feb 17, 2004 | 02:20 PM
prospeed's Avatar
Default Re: (satan_srv)
We have done testing on both heads and believe it or not they are slightly different heads. The ports are smaller and from what i rememeber the intake valves are .5mm smaller. We came across this when we had an F20B head on the Machine to do CNC porting on it. Other then that everything else is the same.
bigsnorlax
May 7, 2009 11:08 AM
chris2000
17
Dec 7, 2006 12:50 PM
JMinSi2000
Aug 16, 2004 08:11 PM
VRD^don
Jan 15, 2003 09:44 AM
