NEED HELP Installing alarm/keyless entry in a 4th gen accord
I need to tap into the wires for the door lock system. they are green/red and green/white. My haynes manual says it will be at the door lock control box. where is that? which molex am i pulling out? I need to know the exact one, the color, all that stuff, I have been under my steering column looking for these wires for almost 3 days. I need help.
Take out the drivers kick panel. Down near the floor under the edge of the carpet you will see a two pin harness sitting there. These are your wires.
drivers kick panel..or it should be a blue plug near there..if not check your factory keyless entry harness. usually located behind stereo.
khronicboy420
Audio / Security / Video
Jan 3, 2009 11:19 AM
