Whats wrong?
I have a 91 Crx hf switched to si with a jdm d15b vtec and when the tach drops from 2000 rpm to 1000 rpm it shakes pretty bad the steering wheel shakes and even the change in the ash tray shakes and it keeps shaking when its on idle at 1000 rpm how can i fix this?
Do they usually shake when they go under 1000 when i put it to 1200 or 1250 its fine i just bought a brand new cluster so it should be ok
When was the last time the plug's and wires were changed? Are the plug wires good and seated, both on the head and dist. What color/condition are tha plugs...
Also, I have ran across info stating that mounts must be installed in a certain way/order or something like that. Or vibrations might occur....
The heater's are adding more load to the engine when they are turned on, because of the alternator needing to create more jucie to run them.
[Modified by 88_SC_CRX_Si, 11:35 AM 1/6/2003]
zumiez007
Jul 10, 2009 12:13 AM
sleepyhamsterlx
Dec 4, 2003 07:35 PM
