Check Engine light came on? Very serious?
Old Jan 4, 2003 | 02:12 AM
97Silver SH's Avatar
Default Check Engine light came on? Very serious?
i just bought my car and the check engine light came on. It never came on before. Its runnin like a brand new ferrari. Could it just be little stuff like Plugs,oil, and fluids? I need to start putting synthetic oil in it cause the other owner probaly didnt.
thanks
Peace
Old Jan 4, 2003 | 04:55 AM
rjr162's Avatar
Default Re: Check Engine light came on? Very serious? (97Silver SH)
most likely it's just an O2 sensor. You can pull the code by popping off the service plug cover (located on the passenger side of your radio, the front most peice of carpeting actually pops off). there's a blue rubber "holder" in there and a blue plug in it (2 wires) just jumper those and turn the car to ignition and watch what code flashs. every long blink is x10, and every short one is one (so 2 long and 5 short is 25)
Old Jan 4, 2003 | 07:59 AM
ViZ's Avatar
ViZ
Default Re: Check Engine light came on? Very serious? (rjr162)
could also be low oil.. h22's consume it like crazy
Old Jan 4, 2003 | 12:26 PM
Default Re: Check Engine light came on? Very serious? (ViZ)
what kind of oil should i use? I had a 4th gen si and i used synthetic. Should i do the same? Does the h23 consume oil like the Vtec h22?
Old Jan 4, 2003 | 12:30 PM
H22Prelude's Avatar
If you can afford it go with synthetic. It's the best for your car. It ends up being around $30 every oil change.
Old Jan 4, 2003 | 01:03 PM
rjr162's Avatar
Typically this would trip the low oil pressure light and not the check engine light.
jrea2008
May 9, 2007 02:56 PM
Deludedteg
Aug 2, 2004 11:48 AM
integraboi1010
May 18, 2004 05:13 AM
kevinoneill
Apr 13, 2004 07:39 PM
