Pressure plate question.
Old Jan 3, 2003 | 04:51 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Pressure plate question.
I have an Action clutch setup that I just installed. I went with their single diaphram heavy duty pressure plate. My question is should the clutch pedal feel this light? I mean it is lighter than stock. The car still shifts fine but I was just wondering about the pedal pressure. I bled the clutch lines pretty good I suppose but maybe I should go back and do it again. Heck maybe I even did it wrong. My procedure.
1. Undo cap and add fluid to resivour
2. Press clutch pedal.
3. Loosen bleeder and let air/fluid squirt out.
4. Close bleeder.
5. Release clutch pedal and press it again.
6. Keep an eye on the resivour to make sure fluid doesn't get too low.
7. Repeat.
Old Jan 3, 2003 | 05:42 PM
Dan GSR's Avatar
Default Re: Pressure plate question. (ActiveAero)
when i did mine...i reversed your step #2 and #3
Old Jan 3, 2003 | 08:54 PM
sgT's Avatar
sgT
Yes its supposed to be that light.
ohsojdmdc
Jul 30, 2014 08:37 AM
scoker83
16
May 12, 2014 07:01 PM
rattlecannedEF
Transmission & Drivetrain
Jun 22, 2010 01:28 AM
TrojanMan01
Sep 21, 2005 10:07 AM
matt2001teg
Aug 26, 2003 09:49 PM
