Type R in 98 hatch question
Old Jan 3, 2003 | 09:48 AM
StudioJDM's Avatar
Default Type R in 98 hatch question
I have a 98 civic hatch and im buying a 97 JDM R swap for it. Just wondering what parts i will need for the swap. Will the type r axles work or will i have to get others? I also hear that I will need an SI rear mount for it. Let me know what all i will need. Thanks
Old Jan 3, 2003 | 12:10 PM
StudioJDM's Avatar
Default Re: Type R in 98 hatch question (ZigenGSR)
anyone??
Old Jan 3, 2003 | 01:37 PM
sivik2nr's Avatar
<FONT COLOR="red">If you get a complete changeover/complete swap you should get everything you need.</FONT>
<FONT COLOR="red"> Yes the Type R axles will work. Use them. And yes you will need to get the 99-00 Si rear and drivers side mounts.</FONT>
If your getting a OBD I motor, which i assume your not, you'll need a OBD II to I adapter harness.
Old Jan 3, 2003 | 03:01 PM
sleeprhatch's Avatar
http://tech.hybridgarage.com/tech/6g...wrence-6g.html
http://www.jspectuning.com/6gen/
If I were you I would get a 98 b18c. Keep with the year of the car.
Old Jan 3, 2003 | 07:47 PM
StudioJDM's Avatar
Default Re: Type R in 98 hatch question (sleeprhatch)
thanks
Old Jan 3, 2003 | 07:48 PM
Nameless RB26's Avatar
You don't need the rear and drivers side mounts.
You need the rear and drivers side BRACKETS! Don't order the mounts!
Old Jan 3, 2003 | 07:50 PM
Default Re: Type R in 98 hatch question (Nameless)
Also, depending on what year of engine you get, you will probably be getting the 36mm axles. They do NOT fit our cars. You'll need to get US spec 94-01 Integra axles.
But I'd wait untill you get everything to make sure they don't send you the right ones. (32mm are right).
Jblack18
Sep 18, 2009 09:03 PM
exotic_type
Nov 15, 2007 04:25 AM
exotic_type
Nov 13, 2007 07:25 PM
futrhondaownr
Mar 8, 2007 12:20 PM
