Where can I buy an OEM replacement gas tank for an Eg?
Old Jan 3, 2003 | 05:59 AM
Fuster_Cluck's Avatar
Default Where can I buy an OEM replacement gas tank for an Eg?
I am just looking to replace my 19 year old gas tank with an OEM replacement when I get my GSR motor. I see other makes / models in JCW for around $100-150, but NO honda's
If this belongs in the "Best Buys" forum please move it......
Thanks!
[Modified by Hybrid93Hatch, 10:00 AM 1/3/2003]
Old Jan 3, 2003 | 06:02 AM
96civich22's Avatar
Default Re: Where can I buy an OEM replacement gas tank for an Eg? (Hybrid93Hatch)
dealership, thats the only place that i found one for sale for my ek when i put a new one in my car for my h22
Old Jan 3, 2003 | 08:55 AM
dwnthehatch's Avatar
http://www.hondaautomotiveparts.com/...gry5=FUEL+TANK
Old Jan 3, 2003 | 09:36 AM
chameleon's Avatar
Default Re: Where can I buy an OEM replacement gas tank for an Eg? (dwnthehatch)
is it beneficial to get a new gas tank if the opportunity arose ? say its a cx and i went with an Si sized that would hold more gas and at the same time we get rid of all the sludge that may be have collected through the years ?? anyone every tried this and seen how much crap is in there?
Old Jan 3, 2003 | 09:39 AM
tommyboy's Avatar
Old Jan 3, 2003 | 10:09 AM
euclid's Avatar
Default Re: Where can I buy an OEM replacement gas tank for an Eg? (tommyboy)
if you just took your tank off, could you clean it? $250+shipping seems like alot for a new tank. also, an si tank will be heavier than your cx tank, most people would prefer a cx tank and i bet if you started searching and posting you could find someone who has an si and replaced it w/ a cx tank... in that case you could buy the si tank for cheap.
Old Jan 4, 2003 | 07:14 PM
96civich22's Avatar
Default Re: Where can I buy an OEM replacement gas tank for an Eg? (euclid)
its good to get a new tank for your car just because of the fact that there is alot of water in gas now a days, and the water doesnt mix with the gas and so it just sits in your tank and gets stagnent and rust inside your tank, so theres not a lot of sluge but alot of water
Old Jan 4, 2003 | 07:17 PM
EK MONEY's Avatar
Default Re: Where can I buy an OEM replacement gas tank for an Eg? (96civich22)
http://www.sohfast.com
Old Jan 4, 2003 | 07:28 PM
euclid's Avatar
my grandfather was actually telling me about a liquid product that you can buy that you pour into a 1/4 full tank of gas. it allows the water to safely mix with the gas and gets burned off in the engine during combustion, then there is no water left in the tank. he said to use it about once a year, i havnt gotten around to it yet, but im sure pepboys or some place like that would carry it. i would make sure its safe first though and there wont be any long term type of engine damage from it.
Old Jan 4, 2003 | 07:31 PM
chameleon's Avatar
let us know the name of that product ..sounds good
Old Jan 5, 2003 | 12:56 AM
Default Re: Where can I buy an OEM replacement gas tank for an Eg? (chameleon)
It's called "Dry Gas"
You can also try this
http://www.summitracing.com
Item No. - 10165 Z
A clean supply of fuel is critical to the performance of your vehicle - hard starting, stumbling under load, and sluggish response may be symptoms that your car's fuel system is dirty. The best way to ensure that the fuel is clean is to be certain that the fuel tank is free of rust. This Gas Tank Sealer Kit seals these minor leaks and can save you a great deal of time and money in trying to locate a replacement tank. For metal tanks up to 20 gallons. Kit contains one 7 oz. can of Metal Wash, 1 pint of rust remover, two 16 oz. bottles of Gas Tank Sealer.
Regular Price: $39.99 This item is in stock.
I used it on my 1972 El Camino. It did the job!
[Modified by dwnthehatch, 4:57 AM 1/5/2003]
tgibson
Jan 1, 2011 07:09 PM
civic_66
Nov 23, 2006 02:20 PM
bdicustoms
Feb 22, 2004 10:24 AM
1hotintegra
Aug 28, 2002 11:30 AM
