EGT probe Q?
Does everyone just thread in the fitting or weld it in ?
also do es it matter if its in the downpipe of the manifold?
it looks like the probe might be too big to go into the manifold,and i dont knwo if i wanna mes siwth my nice manifold ?
what you guys do ?
got any pics ?
what you guys do ?
got any pics ?
most people place in on the 3rd runner. About 1inch to inch and hald away from the flange. Dont worry the prob wont break or burn...aslong as its tapped in there right. BTW im also runnung the maxrev mani.
You can see it if you look close
Thanks! Yeah, it is very close, but it doesn't hit. I would place you wastegate on the manifold, then orient the EGT base around until it's in a good spot, then mark it with a Sharpie and drill it.
what if i put it in like runner #3 facing towards the head?
im just scared to drill this manifold, i dont wanna **** it up
or is where you guys got it the best bet?
2. make sure u want to start out with small drills and work your way up slowly(you dont want to drill a hole thats to big)
Center punch the manifold to give u a guide, so the bit wont slide around.
If your really scared then maybe take to a shop.
Edit: remember you have to tap the manifold so you have threads..not just drilling it.
[Modified by Cramerox, 7:15 PM 1/3/2003]
where can I get a 1/8 NPT tap? Is it just a 1/8 tap and 27 threads per inch or is it a special thread pattern and angle like BSPT? I have a greddy EGT and I need to tap it in, I just need to know where I can get the tap.
same question I'm wondering.
B16Civic93
Oct 3, 2005 08:52 PM
Full-Race Geoff
Apr 28, 2002 07:33 AM
