VAFC fuel cor input ?
It interupts the manifold absolute pressure sensor signal to the ecu.
If you put in +5% for fuel, it changes the MV reading of this sensor to tell the ecu there is 5% more air.
Indirectly. It just changes what the ecu sees as air pressure.
If you tell the VAFC to add 5% it simply interupts the MAP sensor signal and tells the ecu there is 5% more air (in mv).
As a result, the ecu dumps more fuel by lengthening pulse width.
