Hondata or Zdyne
I'm going to be the outcast and say to use the AEM EMS with an obd-0 to obd-1 conversion harness. I've had both the obd-0 and obd-1 hondata on my 88 crx turbo B16 and I was not impressed. I got the 4b cause I figured I would need to tune on my own. Then I bought a wideband.
On all the cars that I've tried the 4b on that came after '92 the system worked like it is supposed to. I was able to datalog air/fuel ratios according to thier position on the fuel map and make adjustments accordingly. When I set everything up in my car I found that no matter what I did the hondata program wouldn't read the correct voltage from the wideband and therefore wouldn't datalog correct air/fuel ratios making it very difficult to tune. I was advised by a hondata dealer that it was because of it being an obd-0 ecu, the pr3 in particular. So, I made the switch to obd-1 and the same thing happened. It appears that there is a significant ground loop in the factory wiring that I couldn't find that caused the readings to be way off. I never got any significant help from hondata and in the end decided to change systems. The only way I could see to make the system work like it was supposed to in my car would have been to rewire the entire car with custom harnesses. There have been a few others that have the same problem. Their names on here are true and slowteg. To my knowledge they have not found a fix to the problem yet.
The aem also sees the wrong voltage but has a gain function that allows you to trim the voltage to make the computer think it is seeing the correct voltage. So far I have been very happy with what the aem can do.
Zdyne you can adjust on the fly and you dont have to burn a new chip or convert your harness. hondata is awsome and dataloggin is rad but who wants to burn a new chip everytime the weather changes?
Just my .2 cents
Blaze
Just my .2 cents
Blaze
