VTEC on H22 not working...
I'm posting this for my brother...
He has a 92 JDM H22a in his 95 accord EX. He's running a chipped P13 ECU, w/ I/H/E. The problem is: VTEC works sometimes, but not others. So what could the problem be? The oil level is perfect, and there are no leaks. VTEC kicked in fine during the first month of the swap, but now, it only works half the time.
We are thinking it may be the ECU, because it was purchased of EBay. What do you guys think? Bad sensor? Or solenoid?
Please help us out if you have any insight.
Thank you all and take care.
i'd check all the wiring first. there may be a lose wire somewhere... if all wiring is ok, then i'd check sensors and go from there.
does the engine light come on at all?
Thanks for the input. Any more ideas guys?
So nick...I see you as well have a JDM swap into your accord...what ECU are you using...any harness changes as well?
Here are the codes he is throwing:
10 - Idle air temp sensor
14 - Idle air control sensor
RooSter
Nov 22, 2007 04:31 PM
