ITR Swaybar Opinion..please read, im a lil confused..!
Ok guys, i installed the bar with the BSQ kit..But..without knocking out any tach welded nuts? where are these..? THE abs wire bracket are off with ease? and ziptied to the bar..am i missing somthing? please inform me..!
I didn't remove the tach weld nuts. My bolt was long enough to get the nut on.
I believe that is the only reason you need to remove the nuts; so that you can get the nut on the bolt
You have to remove the tack weld nut (1 on each side) and drill the whole to make it larger for the bigger and longer bolt. Check here http://geocities.com/bretq/swaybar_install.html
wait so are you saying you could skip that step if you bought smaller and longer bolts?
did this guy possibly drill through the tack welded nuts? It's been awhile since I did the install so I don't really rember all the details.
Well...I drilled threw the ABS Bracket hole with a 5/16 or whatever the BretQ site said...And the bolt just went right threw, and i dropped the LCA and connected the Bolt to the nut..and it went threw fine...Let me know if i endangered the install by doing this..
I do not know how you managed to do the install w/o removing the tack welded nuts.
A few questions:
You purchased all the necessary parts mentioed on BSQ's site?
If you did I am sure you would have had some unsed parts, like the washerand nut
A few questions:
I got everything on BSQ website, this is how my setup is...
Bolt goes threw the following : Swaybar Bushing Bracket>SwaybarBushing>BSQ Plate> Cylinder Type 1/2 inch Spacer> Smaller Thin Washer>SubFrame>TackWelded Nut and is connected on the other side by the Nut...
All i did was drop the LCA to get a easier hand at the end of the Bolt, to get the Nut on it..And the whole install only took about 20 mins..
Swaybar Bushing Bracket>SwaybarBushing>BSQ Plate> Cylinder Type 1/2 inch Spacer> SubFrame>Smaller Thin Washer>TackWelded Nut
ej888
Jun 12, 2010 08:28 PM
Shocka1998LX
Aug 22, 2004 05:11 PM
