max bore on stock sleeves, b18A
Old Jan 2, 2003 | 05:22 PM
fastludeh22's Avatar
Default max bore on stock sleeves, b18A
i did a search and couldnt find anything, although im sure its there. any links or info on this would be very helpfull
Old Jan 2, 2003 | 05:53 PM
HybriDNA's Avatar
Default Re: max bore on stock sleeves, b18A (fastludeh22)
The most and safest bore size that i would go with would be 84mm and thats still not safe depending on what your doing with it.
Old Jan 2, 2003 | 05:54 PM
LsVTeCTuRBo17's Avatar
Default Re: max bore on stock sleeves, b18A (10psi)
It is not safe, in my opinion to boost on any stock sleeve you bore. Every time you bore your sleeve it becomes weaker and weaker.
Old Jan 2, 2003 | 06:19 PM
threatcon13's Avatar
New User
he said "w/out sleeving". You really shouldn't bore your block w/out sleeving.
Old Jan 2, 2003 | 06:35 PM
Default Re: max bore on stock sleeves, b18A (ALLMOTORDC2)
ok heres the sit. i have a xtra b18a laying around. one cylinder from what i can remember was ~ 20 psi lower then the rest on compression check.
i might be getting a 90 hatch for almost nothing, and i will probly be dropping it in there. i dont want to drop it in the way it is, just to pull it out again.
my future goals are unknown since i am finishing up my turbo lude build that i have over 12k in, whichs brings my current debt close to 20 k. i just have this thing for cars, i cant stop. i will prob use n2o cause it is cheap and i can build my own kits. when (not if) i blow it up, i will then rebuild it again, but that is where the next thing comes in.
there is someone selling 83 mm je's for REAL cheap, and i was thinking about using them, but i cant resleeve, i just dont have the money...this was supposed to be a no-money, just parts laying around project, and its already starting w/the forged this, and the balanced that.
other solution i guess would be to get some oem honda pistons that are bigger then the 81 bore, but not to big for stock sleeves. anything from stock compression up(9.x?), cause even turbo i beleave in higher cpompression then most. which pistons can i choose from?
thanks again guys
Vinny
[Modified by fastludeh22, 10:36 PM 1/2/2003]
Old Jan 2, 2003 | 06:39 PM
HybriDNA's Avatar
The most and safest bore size that i would go with would be 84mm he said "w/out sleeving". You really shouldn't bore your block w/out sleeving.
Thats why i said the most and safest "BORE" size not "sleeving" size. And to you to!
Old Jan 2, 2003 | 06:46 PM
New User
most and safest bore size?you were saying to bore it out to 84mm w/out sleeving you moron. read the post topic meatball. "max bore on STOCK sleeves"...you "84mm"
[Modified by ALLMOTORDC2, 8:47 PM 1/2/2003]
Old Jan 2, 2003 | 06:58 PM
eh-D's Avatar
81.5mm
Old Jan 22, 2003 | 06:39 AM
zilverz's Avatar
Default Re: max bore on stock sleeves, b18A (RICErocket03)
why would you bore without sleeving?
im very confused
my b18b is barely bored .. like 10thousanths ... no sleeves or block gaurd here ... been runnin heavy all motor for years 30k miles ..
how about 20thousanths and a block gaurd ?
Walterronny
Honda S2000
11
Oct 29, 2013 07:29 PM
90SiHatchy
Apr 9, 2011 05:13 AM
fusion645
Dec 31, 2009 08:40 PM
b18cTurbo
Feb 9, 2003 08:23 PM
boomslang
Jun 17, 2002 08:10 PM
