Oh crap! Lost 1st and 4th...and reverse...
Old Jan 2, 2003 | 05:09 PM
Finest's Avatar
Default Oh crap! Lost 1st and 4th...and reverse...
I don't know what happened, but I can't even get it into 1st....or reverse.
The clutch pedal feels VERY light now...like it's unattached. Also, I've developed a random rattling noise that's coming from the firewall...but it goes away when I depress the clutch pedal. I'm thinking the two are related....
..but since it's raining cat and dogs outside, I can't work on it til it clears up.
Anyone want to take a guess as to what happened? Or have something similiar happen to them? TIA!
Old Jan 2, 2003 | 05:23 PM
armharm's Avatar
Default Re: Oh crap! Lost 1st and 4th...and reverse... (98CTRCoupe)
sounds like either ur clutch master or slave cylinder... get it checked out... u might just be low on clutch fluid also... same thing happened to me and just adding clutch fluid fixed it..check the resevoir in the engine bay and if its dry fill'er up!
Old Jan 2, 2003 | 06:00 PM
AndyD's Avatar
Default Re: Oh crap! Lost 1st and 4th...and reverse... (armharm)
That's the thing though. If you are low on fluid that means most ikely that your clutch master or slave cyl. is leaking.
Seems like a VERY common problem.
My car has a VERY stiff clutch pedal. A few times my car got stuck in the gear. I was told that my master cyl is leaking.
Hope you don't have a major problem with your car.
Old Jan 2, 2003 | 06:03 PM
armharm's Avatar
Default Re: Oh crap! Lost 1st and 4th...and reverse... (AndyD)
mine is prolly leaking also... but for now the fluid is doing wonders.. i'll just have to wait to fix it..
Old Jan 2, 2003 | 06:09 PM
AndyD's Avatar
Is your clutch pedal firm or light??
Old Jan 2, 2003 | 06:13 PM
armharm's Avatar
very firm
Old Jan 2, 2003 | 06:50 PM
Honda318dx's Avatar
Sounds like your clutch is shot....
Old Jan 2, 2003 | 07:17 PM
armharm's Avatar
Default Re: Oh crap! Lost 1st and 4th...and reverse... (Honda318dx)
when my clutch went out it was still pretty firm... it would just slip a shitload... but when the pedal itself became VERY weak that was either my clutch master or slave cylinder or just the clutch fluid..
Old Jan 2, 2003 | 08:54 PM
Qfactor's Avatar
it's the clutch disc, the spring(s) probably fell out and doesn't let you release. Just worked on one with the same problems.sds
Old Jan 3, 2003 | 02:22 AM
Finest's Avatar
Default Re: Oh crap! Lost 1st and 4th...and reverse... (Qfactor)
Well, it's a new clutch (installed it umm, 5k miles ago?)
But I'll check the MC first.
It better not be the clutch...or else Exospeed is going to hear something from me!
Old Jan 6, 2003 | 04:16 AM
Finest's Avatar
https://honda-tech.com/zerothread?id=377472
Found the problem. Now I need a solution.
*Sorry for forum jumping, but I felt it better suited to be asked in the Tech forum*
[Modified by 98CTRCoupe, 9:22 AM 1/6/2003]
Old Jan 6, 2003 | 07:04 AM
rjr162's Avatar
your link goes to the "submit new topic" screen
Old Jan 6, 2003 | 08:22 AM
Finest's Avatar
Default Re: Oh crap! Lost 1st and 4th...and reverse... (rjr162)
HeHe...jumped the gun.
New link fixed.
evade_07
Dec 13, 2008 10:15 PM
crdcz03
May 5, 2005 06:43 PM
just4747
Jan 25, 2005 08:33 PM
sa21199
Aug 22, 2001 10:37 PM
