o2 sensor wiring question
Old Jan 2, 2003 | 04:12 PM
Soled Out's Avatar
Default o2 sensor wiring question
My CX came with a one wire o2 sensor, but the B16 has a 4 wire o2 sensor on it as im sure you know. I need to know how to wire up the 4 wire o2 sensor that is on the B16 to my PR3 OBD-1 ecu.
TIA
Old Jan 2, 2003 | 05:20 PM
spookhatch24's Avatar
Default Re: o2 sensor wiring question (Gray EG)
am u have to add 3 more wires i know at pin d14 there is one wht wire and a org/blk from a 6 dont know about the other 2
Old Jan 2, 2003 | 05:30 PM
Soled Out's Avatar
Default Re: o2 sensor wiring question (spookhatch24)
AN explanation in english would help, but thanks for trying
Old Jan 2, 2003 | 06:48 PM
Soled Out's Avatar
A25 (yellow/black) black
A6 (orange/black) - black
D22 (green/white) - green
D14 (white/red) - white
Is this correct?
Or can i leave the two wires that heat the sensor disconnected?
Im doing this tommorrow morning and i need to know this, thanx
Old Jan 2, 2003 | 07:33 PM
VTECVillain's Avatar
WHT - D14 (O2 Sensor Input) - needs to be a shielded wire with ground
BLK - A6 (Heater Control)
GRN - D22 (Sensor Ground)
BLK - B1 or A25 (12V+ Power)
Old Jan 2, 2003 | 07:34 PM
Is this correct?
You can't leave any wire without a connection. It would be the same thing as having it unplugged.
Old Jan 2, 2003 | 07:57 PM
Soled Out's Avatar
Default Re: o2 sensor wiring question (VTECVillain)
Thanx, you've been a HUGE help with all my swap questions
Old Jan 2, 2003 | 07:59 PM
poison's Avatar
now THAT is as simple as it gets
Old Jan 3, 2003 | 02:40 AM
seanxhonda's Avatar
Default Re: o2 sensor wiring question (poison)
i have the same problem wiht mine, but i put a d16 in mine from whatever the stock engine is. i need to know how to hook up the 02 sensor wires, please help me out
Old Jan 3, 2003 | 04:12 AM
Default Re: o2 sensor wiring question (seanxhonda)
What motor, car, ecu?
Old Jan 6, 2003 | 04:22 PM
seanxhonda's Avatar
d16z6, in a 92 hatch (cx) now a si. and i am putting a p28 ecu in it. stock harness with the car. and will i have to change my distributor if it was the same one with the stock engine. (1.5)
Old Jan 6, 2003 | 04:24 PM
seanxhonda's Avatar
(correction) WILL i have to change my distributor if it was out of hte stock motor.(1.5)
conguero
Nov 18, 2004 06:36 PM
Sherm
May 23, 2003 12:47 PM
Slow96RedEk
May 16, 2003 08:10 PM
HXMan
Apr 26, 2002 08:13 AM
