Double Jeopardy!!...abnormal Oil Pres. & overheating
Old Jan 2, 2003 | 02:08 PM
b00stedbyFastrax's Avatar
Default Double Jeopardy!!...abnormal Oil Pres. & overheating
Assemble my spare B18c1 over the holidays and installed it new years day. started it up today, everything look good. vacum at 21 in/hg, but oil pressure was a liitle high at idle (around 30 psi). 20 mins later (about 3 fan cycles), the temp gauge went up to 3/4 at idle. it goes down to normal when the fan comes on. now bringing the revs to 2500 rpm, the oil pressure hits 100 psi!WTF! now i am faced with these two problems. can any body shed some light here as to what could be the problem?
Old Jan 2, 2003 | 03:09 PM
BudaKai's Avatar
Default Re: Double Jeopardy!!...abnormal Oil Pres. & overheating (BoostedbyFastrax)
Are you running thinner oil? Umm, what did you do with your oil squirters. Hows your oil pump? Is it new or the original? I'd replace it if it's the original.
Old Jan 2, 2003 | 03:30 PM
Default Re: Double Jeopardy!!...abnormal Oil Pres. & overheating (tzsir)
i am using castrol 20w/50 gtx oil for break-in. as for the oil squirters, i have them capped off and the oil pump is the original one, maybe with 25,000 mi. on it.
Old Jan 2, 2003 | 04:28 PM
qwkteg125's Avatar
how did you cap off your squirters?
Old Jan 2, 2003 | 04:32 PM
Jared's Avatar
I would def fix the cooling system first. How did you bleed the system?
Old Jan 3, 2003 | 04:53 AM
Dublocivic's Avatar
You didnt put any shims in the pump did you?
Old Jan 3, 2003 | 10:02 AM
Default Re: Double Jeopardy!!...abnormal Oil Pres. & overheating (Dublocivic)
the oil squirters came of another b18c1 block that was put together by someone else two yrs ago. not too sure how they did it. also not sure if the engine builder shimmed the oil pump. guess i have to pull apart the whole motor and use back the non capped oil squirters and check the oil pump.
oscar112709
Apr 18, 2019 12:52 AM
ricky28
May 12, 2014 03:38 PM
94ludeJDM
May 4, 2007 06:13 PM
hatchinprogress
Jan 7, 2006 07:48 AM
j954drgsr
Sep 19, 2005 12:55 PM
