Need Axles and Motor Mounts, could use some help :)
i have a b series swap. 1995 civic hatchback.
i need new axles... any recommendations, place to buy, info, thoughts, advice?
i also need new motor mounts.... now my main problem is i have EXTREME WHEEL HOP. I was thinking about getting placeracing motormounts but i heard they shake your car at idle because of the stiffness. how bad is it? if not the placeracing mounts, i have read about motor mount inserts that do a good job too, how do these inserts work? would stock mounts be sufficient (ie, drag, autox). the mounts i would get would be for an ls, or gsr correct?
i wouldnt go with the place racing mounts
id run stock mounts and a couple inserts im running inserts on my 2 bottom mounts not tooooo much vibration but still firm
why dont u recommend going with the place racing mounts? do u recommend i go with just ls or gsr mounts and get the inserts for all 3 mounts? it's 3 mounts in total right? do the inserts do a sufficent job? if the place racing mounts for stability were to be a 10 what would stock mounts with inserts be? thanks man
HASport.com
dafreeeze
19
May 14, 2013 04:33 PM
Bbasso
Mar 4, 2005 05:48 PM
