Exposed Cam Gears- How to?
Old Jan 2, 2003 | 08:55 AM
95IntegraGSRAZ's Avatar
Default Exposed Cam Gears- How to?
Just wanted to know how to proporly expose the cam gears. I love how the engine looks when you can see the cam gears. I know that you can remove the plastic cover on the side where the timeing belt is, but what about the part that is attached to the valve cover?
On a b16 do you have to cut the valve cover? Any pics would be great.
Old Jan 2, 2003 | 08:58 AM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: Exposed Cam Gears- How to? (civicvteckid)
Simply cut the valve cover.
Spade's Avatar
Default Re: Exposed Cam Gears- How to? (vtecvoodoo)
Beat me to it when I was doing your job flaming a noobie.
Old Jan 2, 2003 | 09:00 AM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: Exposed Cam Gears- How to? (Spade)
I was researching your question
Old Jan 2, 2003 | 09:14 AM
Spade's Avatar
Oh, that's the best excuse I have ever heard
Old Jan 2, 2003 | 09:28 AM
GS-Rcivic's Avatar
just like this
Old Jan 2, 2003 | 09:51 AM
Default Re: Exposed Cam Gears- How to? (GS-Rcivic)
what would you suggest cutting with......band saw, dremal tool?
Old Jan 2, 2003 | 09:52 AM
Spade's Avatar
Saw's all with a metal cutting blade.
Old Jan 2, 2003 | 09:56 AM
Saw's-all, even better idea!
Thanks guys
Old Jan 2, 2003 | 10:02 AM
eg6ajk's Avatar
you can have it done...as well someone here on board does them
the shop:
http://www.pmpdesigns.com/On-line_St...lve_cover.html
Old Jan 2, 2003 | 11:33 AM
greebler's Avatar
Default Re: Exposed Cam Gears- How to? (eg6ajk)
What about getting DUST! in the ****, dosn't this cause a problem?
Old Jan 2, 2003 | 11:58 AM
Mr. Thunderlips's Avatar
Useless unless you need to fiddle with the cam gears...
Old Jan 2, 2003 | 12:46 PM
Shawn C's Avatar
In The Garage
Default Re: Exposed Cam Gears- How to? (ThunderLips)
i was beaten to it, but send ur **** to http://www.pmpdesigns.com/On-line_St...lve_cover.html or buy it from them. their work is PERFECT. I would recommend getting the valve cover and the plastic piece. If you do it yourself, it wont look perfect. And dont flame this sayin you did a perfect job yourself if you dont have a laser cutter in the garage. Cause you didnt.
Old Jan 3, 2003 | 09:45 AM
greebler's Avatar
Default Re: Exposed Cam Gears- How to? (22lbGS-R)
so to re-vamp my question
The engine with the cover cut will not be effected by dust and sheit getting on the gears and or belts?
Old Jan 3, 2003 | 09:49 AM
TheHater
Guest
Posts: n/a
You dont even need to send it. Just buy a Type R one while your at it and get it cut its about 150 I think.
Old Jan 3, 2003 | 10:13 AM
blkDOHCsol's Avatar
New User
Default Re: Exposed Cam Gears- How to? (TheHater)
just cut it with a dremel...no point in sending it somewhere
Old Jan 3, 2003 | 10:41 AM
SergEK's Avatar
Nice cuts but unless you value nice work I think most people will elect to chop off the end of the valve cover.
I am currently debating whether or not to send my R valvecover or just a plain black GSR cover in....vat to do, vat to do. Looks clean and will highlight my JDM bLiNg yO (and one less thing to do at the dyno)
Old Jan 3, 2003 | 03:01 PM
jg's Avatar
jg
If memery serves me right, I used a 3 3/4" hole saw purchased from home depot. I think the 4" was bit too large. Worked great! Wedge a wood piece of 2x4 in the area behind where you're going to cut, tape it all to hell with the plastic part in there as well, insert cover into a vise(don't overtighten), and go to town. Go slowly!!! Just figure out where the center of the cam gears are before cutting(it's right at the bottom of the cover- you'll have to make a half round notch at the center points).
here's really bad pic to illustrate the end result...
[Modified by jg, 4:04 PM 1/3/2003]
SoyMilk
Apr 6, 2007 11:34 AM
veilsides2000
Mar 17, 2006 01:20 PM
quicksol95
14
Apr 29, 2004 10:41 AM
Weel
Mar 17, 2004 05:01 PM
sleepin91teg
Jan 23, 2004 07:17 PM
