For everyone who took out there power stearing.
Old Jan 1, 2003 | 09:37 PM
boostedcvc's Avatar
Default For everyone who took out there power steering.
I am currently working on my swap and i wont be needing the power steering any longer. What should i do about the lines from my pump and resevoir? suggestions please!!
[Modified by boostedcvc, 3:28 AM 1/2/2003]
Old Jan 2, 2003 | 05:25 AM
rOby's Avatar
Default Re: For everyone who took out there power steering. (boostedcvc)
i think u have to leave the pump becuz it provides fluid for the rack n pinion. just take ff the belt.
Old Jan 2, 2003 | 05:37 AM
ekb18c's Avatar
if you decided to take the power steering pump off then try to change power steering rack and pinion to a manual rack and pinion so it wont get messed up.
Old Jan 2, 2003 | 08:10 AM
DIY_Racing's Avatar
Hey BOOSTEDCVC. Here is the deal with racks.. Power steering fluid isnt a lubricant. it does NOT lubricate the rack... SO, knowing that you can completly remove your power steering pump, drain ALL the fluid and drive on it forever and you wont have a problem... ONLY side affects are its harder to turn and parallel parking is a bitch... THE GOOD side is you gain anywhere from 5-7hp to the wheels DYNO PROVEN. PLUS, when your on the freeway the car feels alot smoother... you dont get PULLED into ruts as easy, its easier to drive.... I love dit when mine was off for a year and a half, but my wife couldnt park it very well so i put it back on....
anyways.. yank that bitch...
Old Jan 2, 2003 | 08:22 AM
G2turbo_terror's Avatar
Default Re: For everyone who took out there power steering. (DIY_Racing)
there was a write up how you can connect the in/out lines on the rack and tap a line to add a breather so the fluid can stay in the rack, self contained and no pump, I didn't book mark it but do a search, it was very detailed.
Old Jan 2, 2003 | 10:07 AM
turbosol's Avatar
Default Re: For everyone who took out there power steering. (G2turbo_terror)
Search the ITR forum for this, there is a detailed procedure outlined, last time I looked it was over 5 pages long.
Old Jan 2, 2003 | 11:46 AM
Farnsrocket's Avatar
Default Re: For everyone who took out there power steering. (turbosol)
Hey DIY_RACING, are you sure you don't need the fluid. I have always read that you DID need the fluid.
Old Jan 2, 2003 | 11:58 AM
boostedcvc's Avatar
Default Re: For everyone who took out there power steering. (Farnsrocket)
thanks for the replies so far guys, ill check the itr forum.
Old Jan 2, 2003 | 12:08 PM
DIY_Racing's Avatar
FARNSROCKET. Yes i am very sure. The fluid is what pushes the rack. There is no lubrication needed. Two friends, and myself have ran BONE dry racks for a total of 3 years... RACE track, daily driving. Not one problem. Only reason people will leave fluid in the rack and block it off is it is supposed to make turning without the powersteering a bit easier... In my opinion its not. ahah Its just as tough with or without it. I work for a car dealership and your best bet is go ask a technician... They will tell ya..
Old Jan 2, 2003 | 02:54 PM
lilxvtecxpwr's Avatar
i took out my power steering pump and left the powersteering fluid hose and zip tied it to the strut bar. havent had any problems with it.
Old Jan 2, 2003 | 03:07 PM
Drew Peacock's Avatar
Default Re: For everyone who took out there power steering. (lilxvtecxpwr)
Is it worth it though ?>? I wouldn't mind getting rid of my light touch steering.. its to jittery.
Old Jan 2, 2003 | 03:15 PM
inspyral's Avatar
Default Re: For everyone who took out there power steering. (turbozxi)
https://honda-tech.com/zerothread?id=184202
Old Jan 2, 2003 | 07:48 PM
MyWhiteCivic's Avatar
I'm thinking of removing my PS too. I was thinking of removing the belt and draining the fluid. Will that work?
Old Jan 3, 2003 | 09:45 AM
turbosol's Avatar
Default Re: For everyone who took out there power steering. (MyWhiteCivic)
Inspyral found it, works great I've done this on my del sol and 00 si, plus a few of my friends have done and they won't ever go back.
blackj30_a
Jun 2, 2022 06:16 PM
rolledthatho
13
Feb 12, 2011 06:13 AM
Hondaphile13
11
Jul 12, 2009 06:39 PM
FaTBastarDinaCiviC
Oct 14, 2001 02:00 PM
