Crank Pulley is no more.
Old Jan 1, 2003 | 09:14 PM
94TealGSR's Avatar
Default Crank Pulley is no more.
My question is this: Can I put lock-tite on the crank pulley bolt to stop this thing coming loose again? Is there anything wrong with doing so? Any other suggestions?
:Here's the full story of it flying off:
The threads on the crank (where the pulley bolt goes in) are stripped right at the end... they have been ever since I bought the motor. It ran fine for about 6 months, then the bolt started to come loose... it ate all my belts and the pulley rattled itself around untill it broke pieces off. I got another one, put it on as tight as I possibly could (with an impact wrench), and all was good. Untill about half an hour ago. I was out driving, and I feel something shaking and I hear this noise almost reminiscent of an exhaust leak? I decide to head straight home, since I was pretty close. Anyway, I hear a bolt come loose, and I figure it was just a loose bolt on my exhaust that had come loose and rattled off. A few seconds later, my battery light came on, and I knew immediatley what it was. I end up making it home, and as I'm pulling into my driveway the thing flew off.
Now I need a new crank pulley, and some new belts.
Old Jan 1, 2003 | 09:22 PM
smkngsr's Avatar
Default Re: Crank Pulley is no more. (94TealGSR)
since its already stripped...u might want to try re-threading those bolts and the crank hole...if that does not work, u can put a heat resistant locktite to prevent it from coming lose or u can get some JB Weld and put some on it...just right around it...so it does not come lose when rev higher...hope this helps...i highly recommend re-threading first...
Old Jan 1, 2003 | 09:24 PM
94TealGSR's Avatar
Default Re: Crank Pulley is no more. (smkngsr)
I thought about reathreading it... but then I'm scared to mess with my crank, know what I mean? It's majorly important and stuff.
How hard is it to rethread? I've rethreaded bolts on other stuff before, but never on anything relating to the car.
Old Jan 2, 2003 | 08:34 AM
94TealGSR's Avatar
Anyone else? I'd like to fix this today.
Old Jan 2, 2003 | 08:51 AM
ragejed's Avatar
FYI: JD weld does not work well in cold climates...Only warm ones. Therefore it will not bold well to cold metal.
Old Jan 2, 2003 | 09:19 AM
94TealGSR's Avatar
Default Re: Crank Pulley is no more. (ragejed)
Well, fortunatley I live in Florida, coldest it ever gets here is about 40 degrees... right now it's 72F. If I put JB Weld on it, will I be able to take the crank pulley off when the time comes? I realize I'm kind of looking for the best of both worlds, but it needs to come off when I need it off (to change timing belt, oil pump, whatever), and not to come off by itself... sometimes I hate my car.
EDIT: Does JB weld stand up to high temps? I know I have some in the garage, but I've never used it. My brother's the one thats always using it.
[Modified by 94TealGSR, 1:20 PM 1/2/2003]
Old Jan 2, 2003 | 08:25 PM
Danger's Avatar
almost had that happen to me in my crx . i kept hearing a wierd tickin noise comin from under the hood so i thought it might be the valves or sumthing . so i went to put the wrench on the crank pulley bolt and it fell off glad i wasnt driving .
Old Jan 3, 2003 | 06:40 AM
94TealGSR's Avatar
Default Re: Crank Pulley is no more. (jonny5)
Yeah, I made it home just in time for my pulley to fall off in my driveway, and get stuck under my front tire...
Last bump before I let it drop. Probably gonna put some JB Weld on it.
barrera
Oct 11, 2010 07:17 AM
jdmstreethatch
Apr 22, 2005 09:12 PM
civiceg500
Nov 15, 2004 06:29 PM
accord2fix
Jun 7, 2004 10:57 PM
95lude-s
Mar 17, 2004 01:25 PM
