Mr2 injectors on a del sol
Old Jan 1, 2003 | 07:15 PM
94jdmsol's Avatar
Default Mr2 injectors on a del sol
i got a 94 del sol thats supercharged, and i need some injectors so i ordered some mr2 aftermarket injectors for 50 bucks, which was a good deal, but i heard that the injector pulse is different , is there any truth to this rumor? or will it work fine with my stock ecu, cuz i do have a vafc and a whole lotta stuff on the car, if you guys can help me out i'd really appreciate it....and their 375cc injectors by the way..
Old Jan 1, 2003 | 07:38 PM
jdmcivicferio's Avatar
Default Re: Mr2 injectors on a del sol (94jdmsol)
if i'm not mistaken you need to get a prelude resistor pack or accord resistor pack because the mr2 injectors are peak and hold and the ones in your del sol are saturated.
Old Jan 2, 2003 | 06:49 PM
94jdmsol's Avatar
Default Re: Mr2 injectors on a del sol (jdmcivicferio)
so if i get a resistor pack from a prelude it'll work on the b16??? and one more question what does a resistor pack do???
Old Jan 2, 2003 | 08:10 PM
yes you can get a resistor pack from a prelude or accord, I am not very good at explaining it but the injectors from majority of other cars with a higher rate of cc require a different ohmage to work correctly or you will fry your ecu and get no performance gains. go to http://www.hondata.com it will probably sum it up better cause I suck at explaining stuff, but I hope that helped a bit.
Old Jan 6, 2003 | 09:14 AM
chirish's Avatar
3SGTE Mr2 injectors are 440cc, not 375cc. If I remember correctly, the clip is different and will not work on a Honda fuel rail.
BlueVxIDelSlo
11
Apr 12, 2011 07:55 PM
crizx89
12
Nov 3, 2010 08:56 AM
Del_Slowest
Dec 7, 2003 10:24 AM
deftones0817
Nov 17, 2002 04:57 PM
