Does a 92-95 EX/SI harness have a knock sensor wire already wired?
Old Jan 1, 2003 | 03:58 PM
Prevail's Avatar
Default Does a 92-95 EX/SI harness have a knock sensor wire already wired?
I just ordered a harness from a 92-95 EX civic..
Swap is going into a 94 CX Hatchback
Will this have EVERY wire I need to run? I know it has everything for VTEC already, but I'm not sure on the knock sensor.
Its a JDM B16A/P30 ECU
If not, what wires will I need to run myself??
Thanks~
Old Jan 1, 2003 | 04:18 PM
vladd's Avatar
Default Re: Does a 92-95 EX/SI harness have a knock sensor wire already wired? (ride_with_me)
Thanks~
knock sensors came on 96+ civic's.
Old Jan 1, 2003 | 04:24 PM
JV's Avatar
JV
Who?
Default Re: Does a 92-95 EX/SI harness have a knock sensor wire already wired? (civicdxtyper)
P28 doesn't look for knock...
Old Jan 1, 2003 | 04:28 PM
ce's Avatar
ce
No knock sensor in a JDM P30...So don't bother
Old Jan 1, 2003 | 05:30 PM
Prevail's Avatar
Default Re: Does a 92-95 EX/SI harness have a knock sensor wire already wired? (ce)
Right on, so with the EX Harness it will be 100% plug n play? Won't have to run any other wires?
Old Jan 1, 2003 | 06:20 PM
chad's Avatar
Moderator
you will need to add wires for vtechk and vteckh oil pressure....in the chasis wire harness not the one you bought! unless the car is a 92 cx....or an si
Old Jan 1, 2003 | 06:40 PM
VTECVillain's Avatar
Default Re: Does a 92-95 EX/SI harness have a knock sensor wire already wired? (Chad)
Or a VX or EX....
Old Jan 1, 2003 | 09:27 PM
Prevail's Avatar
I bought the entire thing from engine to ECU!
Old Jan 1, 2003 | 10:36 PM
92b16vx's Avatar
The cx doesn't run a vtec.The wires are in the harness but don't go to the motor nor does the dx,vtec=si,ex,and vx
Old Jan 1, 2003 | 11:41 PM
function83's Avatar
errr wrong,
there is a knock sensor even in the very rare very small jdm p30 ecu.
in fact the motor comes with a knock sensor.
every stock b series ecu has a knock sensor. open it up it should have a knock board.
and i second that you will need to add the 3 vtec wires and 1 knock wire in the chassis wiring harness.
[Modified by djhatch, 8:42 AM 1/2/2003]
Old Jan 1, 2003 | 11:57 PM
92b16vx's Avatar
Default Re: Does a 92-95 EX/SI harness have a knock sensor wire already wired? (djhatch)
errr wrong,
EDM B16a2 P30 ecu's don't.
Old Jan 2, 2003 | 04:03 AM
Prevail's Avatar
Default Re: Does a 92-95 EX/SI harness have a knock sensor wire already wired? (92b16vx)
Ok, let me clarify:
I have a 94 CX.
I am putting a JDM B16A into it.
I bought the COMPLETE wiring harness from engine to ECU, from a 92-95 EX Civic. Even with this harness, you are telling me that I need to run VTEC wires, even though EX models have VTEC????
confused...
I was told I wouldn't have to run anything if I bought this harness.
Old Jan 2, 2003 | 04:49 AM
You WILL have to run the wires from the connection at the shock tower to the ECU only. Since you have an EX engine harness the VTEC wiring is in that, just not on the cabin side of your car. I wouldn't have bothered buying the harness and just used the CX harness and added the wires. You said that you got the entire harness into the ECU so I guess if you were to use it completely there would be no wiring.
crxb16ftw
May 23, 2007 09:32 PM
NuRv
Nov 21, 2004 02:18 PM
civiceg500
Jun 26, 2004 06:36 AM
stockegsix
May 11, 2003 10:17 PM
g's integ
Apr 19, 2002 05:05 PM
