ok , i got a 96 SI head , intake mani ,and throttle Body, what else do i need to go onto my CX block
Old Jan 1, 2003 | 12:11 PM
civicracer1993's Avatar
Default ok , i got a 96 SI head , intake mani ,and throttle Body, what else do i need to go onto my CX block
i think ill need some kind of different wiring harness and an ECU from a 92-95 SI .. anyone got this for sale and is there anything else ill need to put the 96 SI head on my 93 CX block and have it run right?? also what about my distributor? will that work with the 96 head??
Old Jan 1, 2003 | 12:14 PM
mantic6t9's Avatar
Default Re: ok , i got a 96 SI head , intake mani ,and throttle Body, what else do i need to go onto my CX b
96 si head? Canadian?
Old Jan 1, 2003 | 12:40 PM
92CIVICCX's Avatar
the cx motor regaurdlees is garbage save for a swap.. trust me... mini me no not for the cx block.. the cx tranny is garbage
Old Jan 1, 2003 | 01:23 PM
civicmatt's Avatar
The 8 valve cx motor might not have enough valve indents on the pistons for a head swap. For as much money as you would spend on swapping the head, ecu, tranny, and everything, you could have bought a nice 95 Si/ex motor. Do it right the first time.
Old Jan 2, 2003 | 07:18 PM
well i already got most everything i need , im not gonna swap the tranny. will this cause a problem??
Old Jan 2, 2003 | 08:03 PM
Shawn C's Avatar
In The Garage
im guessing youre talkin about a D16Y8 head?? if i was u id save up and get a good bottom end too. how about a cheap *** D16Z6 bottom?
Old Jan 2, 2003 | 08:27 PM
Evil_Wizard's Avatar
Why in the hell do you feel the need to post 3 or 4 different posts about the same damn thing? You have ask basically the same damn question at least 3 times. And I am still waiting for you to explain what in the hell a 96 SI is?????????
sinister357
17
Dec 1, 2004 06:32 PM
civicracer1993
Dec 29, 2002 11:09 PM
civicracer1993
Dec 15, 2002 06:38 PM
1sick4door
Mar 7, 2002 08:19 PM
