Best way to clean out engine bay?
Old Jan 1, 2003 | 09:35 AM
Sean K's Avatar
Default Best way to clean out engine bay?
Like the title says, what is the best way to do it? Is it ok just to use one of those high pressure hoses at the car wash?
Also, I have a cam seal that may be going bad. Will that be a problem?
Old Jan 1, 2003 | 09:52 AM
vtecsoldseperately's Avatar
Default Re: Best way to clean out engine bay? (Sean K)
there was a thread not too long ago about this... use search.
Old Jan 1, 2003 | 10:00 AM
Sean K's Avatar
Default Re: Best way to clean out engine bay? (vtecsoldseperately)
Ok. that helped.
What should I cover up, though?
Old Jan 1, 2003 | 10:04 AM
Full Race EG's Avatar
battery and distributor
[Modified by IntegraLStuner, 11:05 AM 1/1/2003]
Old Jan 1, 2003 | 10:38 AM
LSRydeR's Avatar
here's a link to a site that'll show you how to clean your engine bay... it's from one of the bimmer guys over at bimmerforums.com
http://www.apexcone.com/TechProcedur.../ArmorAll.html
Old Jan 1, 2003 | 10:40 AM
Type Wah's Avatar
Default Re: Best way to clean out engine bay? (LSRydeR)
Armor all works a miracle, i use it on my valve cover.. shiny *** man!
Old Jan 1, 2003 | 10:54 AM
DrunkNRacer's Avatar
Get some ENGINE GUNK.. **** works like a charm.. and Armor All on all the plastic n rubber. Youll be blinging for the hunnies (sarcasm)
Old Jan 1, 2003 | 12:43 PM
mickey513's Avatar
Default Re: Best way to clean out engine bay? (Type Wah)
Do not use armor all on any hose in the engine bay, it has been to cause the hose to dry up and crack.
Old Jan 1, 2003 | 12:48 PM
tegasaurus's Avatar
Default Re: Best way to clean out engine bay? (mickey513)
simple green.... i didn't even cover up my battery... i just put a plastic bag around my air filter and suh-ran (can't spell, so i sounded it out hehe) wrap around my coil. I used water to wet everything down... sprayed on 100% full strength simple green... scrubbed... and all gunk/grime came off easily.
Simple green + exterminator (big pump pressurized containers) like sray bottle
-Ryan
Old Jan 2, 2003 | 09:44 AM
ebelp's Avatar
Default Re: Best way to clean out engine bay? (tegasaurus)
Are those of you with CAI's covering your air filters up too?
Old Jan 2, 2003 | 11:08 AM
Default Re: Best way to clean out engine bay? (ebelp)
You can wrap up the Filter head with plastic if you want
Old Jan 2, 2003 | 03:23 PM
redman223's Avatar
Default Re: Best way to clean out engine bay? (SlowAssAccord)
Castrol Super Clean is the absolute best, I tried everything, and none of it would take off the dirt and grease on the firewall without scrubbing, and with all those lines that is pretty hard to do. But then I sprayed on super clean, and it simply washed away all that stuff without any scrubbing at all!!!!!!!!! Awesome stuff.
Old Jan 2, 2003 | 04:25 PM
XDEep's Avatar
Default Re: Best way to clean out engine bay? (redman223)
i dont think ill ever do anything like that.. maybe with a damp cloth or very, very carefully in sectioned off areas. ive had enough electrical mishaps (12 year old car tho) and i dont want to risk any more. i also know someone personally who washed his engine several times and his speedo cable screw up several times. vtec wouldnt work, and the speedo would just jump around. luckily he was under warranty. well it happened yet again and hes no longer under warranty. i think the list price is 120.
anyways, the concensus seems to be, 'oh ya sure, just wrap up the connectors and spray her down', not just from here, but from everyone ive ever talked to or read about. i just think great care should be taken, only expose the solvent to metal.. make sure its safe for rubber, else dont get a single drop on anything. seal off everything not metal. if you think it may leak, assume it will. work in sections, and wipe down with a cloth when you can, dont just wrap up and spray like a madman.
welp thats just me. im so paranoid id probably remove the distributor, fuel rail and connectors, fuse box, and especially the o2 sensor. i think it should be done with as much care as doing engine internals. i just cant afford to have any glitches with uncertain causes anywhere. good luck.
jlh22179tx
10
Mar 11, 2007 05:53 PM
dd PA da
14
Apr 16, 2004 09:10 AM
EF-9SiR
Mar 10, 2003 04:56 PM
PYITR821
Jun 6, 2002 04:30 PM
wessieball
Apr 22, 2002 01:02 PM
