Teg won't start!
Old Jan 1, 2003 | 08:34 AM
psychotic_z's Avatar
Default Teg won't start!
Ok, just finished my rebuild of my 92 LS last night and charged the dead battery this morning. But now when I turn the key, it cranks over, but won't run. When it cranks, it appears not all the cylinders are firing... It cranks, then coughs a little, goes back to cranking. I don't know. Fuel is good, albeit a month or two old, spark is going to all cylinders, double checked wires on distributor cap... I'm not too sure what to try next. Any idears?
Old Jan 1, 2003 | 08:59 AM
zilverz's Avatar
Default Re: Teg won't start! (psychotic_z)
Inside the distributor, are the contacts on the Cap and Rotor still in good shape?
Old Jan 1, 2003 | 09:59 AM
Vtec integra's Avatar
did you align the distributor cap rotor right? i remember the same thing happenning with my friends ls when we changed his cap and rotor. it has to be aligned with the top dead center and the rotor on the number 1 spark plug place. summin like that. i know it doesnt matter on a gs-r but on ls it does.
Old Jan 1, 2003 | 11:14 AM
It runs now! Sorta... It turned out to be cam timing; intake cam must have slipped a tooth or two. But, it runs now! Shweeet.. However, during the 20 minute break-in for my new cams, my coolant gauge read nothing, and my radiator fans never kicked on. It's out cooling off right now, but I assume my coolant temp sensor either isn't reading or I missed a connection . I won't get to screw with it until tonight though, work calls . Thanks though!
KING_LIAN
Feb 23, 2008 02:59 PM
lilgreenlude93
Apr 7, 2004 10:20 PM
Spoonin
May 29, 2003 07:23 PM
aktc167
Apr 28, 2003 11:46 AM
hoysum_dimsum
Feb 15, 2003 05:39 PM
