bouncing, non-working, then working speedo
So I was driving today, and at first my speedo wasnt working, then it would bounce around to like 20 or 40 (i was going 70-75), then it would go back to the correct speed, bounce down again, go to 0, then to 20 and just stay there, then went back up to the correct speed. Whats going on here?
Your car is posessed.. Burn that demon car.. Just Kidding
You should check the VSS fuse in the fuse panel by the clutch. (7.5A).. it could be blown.. Replace it and reset the ECU. Also check your PGM-FI fuse.
If it still does that, I would check your distributor. Or it could be a loose battery clamp.
[Modified by SlowAssAccord, 3:47 PM 1/1/2003]
Mine has similar problems. When I haven't driven the car for a day or two, every once in a while, the speedo wont work for approx 2 miles.. it just reads 0. Then all of a sudden it will just pop up to speed, and everything is fine from there. Very weird, a fix would be good.
pacey
12
Aug 18, 2009 11:24 PM
superchi
Oct 26, 2008 03:49 PM
