Speedometer acting funny
Old Nov 19, 2002 | 11:47 AM
sgT's Avatar
sgT
Default Speedometer acting funny
It is inconsistent and jumps around. anyone remember what the cause is?
Old Nov 19, 2002 | 11:48 AM
yoshi234's Avatar
I shoot brides
Default Re: Speedometer acting funny (sgT)
bad vss?
Old Nov 19, 2002 | 11:49 AM
jetydosa's Avatar
25 Year Member
I had same problem ater auto-x this weekend. I had CEL on, and speedo was either all over the place, or just at zero even when moving. I checked the VSS fuse in the fuse panel (7.5A) and it was blown. I replaced the fuse, reset ecu and all is back to normal.
[Modified by Jetydosa, 3:50 PM 11/19/2002]
Old Nov 19, 2002 | 11:50 AM
RATEDR's Avatar
Speed sensor fuse is probably blown. Check your fuses on the inside of the car by your clutch pedal. Im pretty sure thats it.
Old Nov 19, 2002 | 11:51 AM
RATEDR's Avatar
Default Re: Speedometer acting funny (Jetydosa)
Damn, Stephen beat me by one minute.
Old Nov 19, 2002 | 11:52 AM
Mugen Mike's Avatar
I have the same problem occasionally. Only under WOT
Old Nov 19, 2002 | 11:56 AM
RTW DC2R's Avatar
Default Re: Speedometer acting funny (mugenmike)
my tach does that when i bounce it off the rev limiter lol
Old Nov 19, 2002 | 12:02 PM
Reid's Avatar
Global Moderator
Default Re: Speedometer acting funny (RTW DC2)
If it's not VSS related, I'd check the distributor.
Old Nov 19, 2002 | 12:05 PM
dohcsideSi's Avatar
Default Re: Speedometer acting funny (Reid)
yea if you notice any loss of power when it happens...usually a bad ground...ignitor going out
Old Nov 19, 2002 | 12:08 PM
Cheap Bastard's Avatar
New User
Default Re: Speedometer acting funny (dohcsideSi)
I had a similar problem and I traced it to a loose battery clamp.
Old Nov 19, 2002 | 12:10 PM
Dave-ROR's Avatar
another fuse did this to assdime's car.. something regarding the alternator, but I forgot which fuse, sorry.
Old Nov 19, 2002 | 12:50 PM
sgT's Avatar
sgT
distributor is BRAND new..... but that doesnt really mean anything.
i'll check the fuses though. thanks.
Smitdog's Avatar
Default Re: Speedometer acting funny (Dave-ROR)
Steve, My VSS is bad. At 99mph my Speedo stops but car still accelerates like normal! Been to lazy to get a new VSS, how often do I go ova 100mph anyway!
Old Nov 19, 2002 | 12:52 PM
sgT's Avatar
sgT
Default Re: Speedometer acting funny (Smitdog)
my VSS is good.
Old Nov 19, 2002 | 01:03 PM
Reid's Avatar
Global Moderator
If all else fails, try stealing err--"borrowing" the speedometer out of Ed's car to see if that stops the problem.
Old Nov 19, 2002 | 01:10 PM
ZygSpeed's Avatar
I heard that ... haha
Secondary O2/VSS/grounds/shorting etc.
Sounds like after Craig was done running open header at the last ITR EXPO.
I believe he shorted either the power or signal wires.
[Modified by Zygspeed, 5:10 PM 11/19/2002]
Old Nov 19, 2002 | 01:14 PM
Austin's Avatar
Default Re: Speedometer acting funny (Zygspeed)
That would be the heater circuit...and I did that at the ITR EXPO #1, funny that someone did that at #2...
Old Nov 19, 2002 | 01:15 PM
sgT's Avatar
sgT
Default Re: Speedometer acting funny (Austin)
there is no 2ndary O2
Old Nov 19, 2002 | 02:33 PM
TurboITR's Avatar
- vss/alternator fuse - 7.5amp underdash
- short in vss wire @ the ecu harness
- bad battery connectors - ground with resistance
- bad ELD
- alternator/charging system short
had this happen recently
[Modified by TurboITR, 6:36 PM 11/19/2002]
Old Nov 19, 2002 | 05:41 PM
sgT's Avatar
sgT
Default Re: Speedometer acting funny (TurboITR)
- bad ELD
I have no alternator/vss fuse
Old Nov 19, 2002 | 06:06 PM
sackdz's Avatar
Might as well check the PGM-FI fuse while you're at it..
Old Nov 19, 2002 | 06:11 PM
SurferX's Avatar
My speedo did this, turns out the spring was bad. It would work fine sometimes and other times it would stick in places. Acura replaced the speedo for free saying it was on some sort of service recall but also my car was still under warranty so I don't know how they would handle cars out of warranty with it.
Old Nov 19, 2002 | 06:30 PM
sgT's Avatar
sgT
Default Re: Speedometer acting funny (SurferX)
the speedo is like 400 retail i think hahaha.....
if it comes to that, i'l judge speed by rpm. its not hard for me
but hoping its electrical
Old Nov 19, 2002 | 06:31 PM
uNF$@#!'s Avatar
by now steve you still dont have the mph memorized from rpm/gear?
Old Nov 19, 2002 | 06:32 PM
baonest1's Avatar
how bouts the connectors in the back of the speedo.. everything up to par??(no bad wired, shorts or anything)
[Modified by baonest, 10:32 PM 11/19/2002]
