brake problem
Old Dec 31, 2002 | 04:17 PM
thecorey's Avatar
Default brake problem
yesterday i noticed that when i pressed the brake the idle started bouncing...when i let off...it went back to normal...so today im driving around and i go to press the brake and its hard as hell to press down...and its still causing the idle to bounce...i took off the vacuum line between the master cylinder and the intake manifold..and blew through it..it seems to be fine...i tested out the little one way valve..and it works...anyone know what i need to replace?
oh yeh i forgot to mention that also..right when the pedal got so hard to press in...it started making a hissing sound...inside the car..
[Modified by thekori, 1:21 AM 1/1/2003]
Old Dec 31, 2002 | 07:39 PM
SIRX's Avatar
Default Re: brake problem (thekori)
Sounds like your brake booster is shot. That's the hissing noise you here. When you step on the brakes you are losing all of your vacumn and the motor runs crappy. Goodluck
Old Dec 31, 2002 | 09:29 PM
93civicd16's Avatar
Default Re: brake problem (SIRX)
that'd be my guess too
Old Jan 1, 2003 | 10:25 AM
thecorey's Avatar
Default Re: brake problem (93civicd16)
thanks...so i just replace the whole booster? i think my master cylinder is leaking too...so i may just replace both....anyone else have any input?
Old Jan 1, 2003 | 10:32 AM
Ef Whore's Avatar
u might as well replace both, after that your ****'ll be nice.
Old Jan 1, 2003 | 01:55 PM
91_hatch_si's Avatar
get a teg master cylinder
Old Jan 3, 2003 | 06:51 AM
88_SC_CRX_Si's Avatar
New User
Then have your brake system flushed, that right there will give a vast improvement....
Randysi
26
Jul 26, 2012 03:28 AM
project91crxsi
10
Sep 21, 2009 04:54 PM
dhiltibidal
Jun 22, 2008 07:12 PM
slipperyduck
10
Jul 11, 2004 11:42 AM
snoop_bealybob
Oct 18, 2002 04:49 AM
