what rods, pistons, and crank would work alright in my 94 teg RS???
would it be possiblw for me to use itr rods, crank, and pistons in my rs?
cuz i know the bores are a little different, but its not much at all, or what are some other ecommendations??
i dont think the rods and crank would work . pistons would work perfect , you use them .
[Modified by jonny5, 6:32 AM 1/1/2003]
ITR rods and crank go together as a pair. Same thing with the B18 non-VTEC rods and crank. Don't mix-n-match b/w the two.
All B-series (except B20) engines have a std 81mm bore. Pistons are interchangeable. Slight modifications needed if mixing and matching B18A/B rods or B16 rods with B18C pistons.
well, i just mostly want a stronger set of rods for my car, cuz i know the ls rods arent the strongest by ny means, would i be better off justgoing with eagle h beam rods??
there are crower rods for sale for about 350 i think and HT gets a deal or something
where at?
also, how hard would it be to install new pistons/rods, without pulling the motor? just out of curiosity? or is it just way better off pulling it and gettin her dialed?
so the eagle h beam rods on itr pistons with a stock ls crank would be an ideal setup?
If you're gonna go through the trouble of putting that stuff in, you might as well pull the motor.
Not a good idea to half *** the job.
if you are looking for the eagle rods im sure u can find them in the "best buy" forum or try usin the "search" function . sumtimes it helps but not always .
