Checkin out my swap and found this....?
Old Dec 31, 2002 | 11:44 AM
b16_madman's Avatar
Default Checkin out my swap and found this....?
it was danglin behind my motor...so i ziptied it to the throttle cable....it runs fine....shoudl i bother???
Old Dec 31, 2002 | 11:51 AM
rainmanEK's Avatar
big strong guy
Default Re: Checkin out my swap and found this....? (B16_madman)
What year engine? Looks like perhaps a First Gen. B16a!
Is you alternator pluged in?
Is it for crusie control? ( never seen a cruise control plug )
Werid?
eric
Old Dec 31, 2002 | 11:56 AM
primoEF's Avatar
could that be for the EVAC? or something like that
Old Dec 31, 2002 | 12:03 PM
b16_madman's Avatar
Default Re: Checkin out my swap and found this....? (EFDog)
1st gen b16....possibly from my dx harness....alternator is plugged in...i dunno....?
the other day i decided to drop it down in 4th at like 65....looked down a few sec's later and saw 105....woah...this gots power now!
more new pics in appearance and cosmetics....under 88 sleeper
[Modified by B16_madman, 1:05 PM 12/31/2002]
Old Dec 31, 2002 | 12:06 PM
Hcivic88's Avatar
flashing any codes maybe??
that'd be the first thing I'd check.
all sensors and everything hooked up? you dont see anything around that area where it may plug into? or maybe it has to be extended to plug in somewhere else.
Old Dec 31, 2002 | 12:08 PM
b16_madman's Avatar
Default Re: Checkin out my swap and found this....? (Hcivic88)
no check engine light...but ill check the ecu....also what about this????
Old Dec 31, 2002 | 12:12 PM
shortyz's Avatar
those look like bolt studs that hold your fuel rail on.
Old Dec 31, 2002 | 12:20 PM
Flexmyrex's Avatar
if youre refering to the two bolts, no thats not for the clutch cable.
it holds a black box in place. wires run inside the box to your injectors. i see that you dont have the box but i doubt it would cause any probs, it is supposed to be a heat shield.
Old Dec 31, 2002 | 12:37 PM
USDM 4G VTEC's Avatar
what colors are on those 2 cables of that sensor ,..,
on a DX to Si or any other swap u got a extra plug that doesnt need to be hooked up..
i have that extra plug on ym Z6.... no big deal .. looks like the plug that came off ur EACV... tell me the colors...
i can tell the red color...
if its:
red/yel and grn/wht its the TA sensor
blk/yel and blu/yel its the EACV
Red/wht and grn/wht its the TW sensor
hope it helps..
Old Dec 31, 2002 | 02:06 PM
ThatRicerDaniel's Avatar
i have that plug too. it was on my Si harness. i just didnt plug it in .. but another swap i had that plug and i pluged in to the back of the motor and the fan came on .. trip out . i dunno.
Old Dec 31, 2002 | 02:12 PM
CRX7's Avatar
Default Re: Checkin out my swap and found this....? (NitrousDreamz)
I also have a DX to B16a swap and that one is not necessary, mine is dangling too. I forget what it goes to though, but don't worry about it.
Old Dec 31, 2002 | 02:21 PM
johnzm's Avatar
Default Re: Checkin out my swap and found this....? (CRX7)
gu7ys the d16a6 has a mini IAC and amain IAC. the b16 only has one.
Old Dec 31, 2002 | 05:26 PM
b16_madman's Avatar
Default Re: Checkin out my swap and found this....? (johnzm)
ok thanks guys...i wont worry about it now....
Old Dec 31, 2002 | 05:41 PM
FitCRX's Avatar
[QUOTE
[/QUOTE]
Is your mani temp sensor in? that conector looks like the one in this pic. Below the fuel regulator just to the right.
Old Dec 31, 2002 | 06:55 PM
CRX-RX's Avatar
Perhaps your thinking of the fast idle air control vavle found on the 90-1 Si's. If that's the case, that's not the right plug style for that valve. Is there only a single wire on that connector? Do you have your knock sensor plugged in? Colors are key here.
Old Dec 31, 2002 | 11:10 PM
RCautoworks's Avatar
Default Re: Checkin out my swap and found this....? (CRX-RX)
I have the dx to b16 swap to, I actually had this switched with the eacv sensor I think. Anyways I thought it was the knock sensor, but it plugs in under the intake manifold or some where around there. I am trying to get some more information on it, but for now thats all I have.
Old Dec 31, 2002 | 11:15 PM
Default Re: Checkin out my swap and found this....? (90blackcrx)
I just found this on hasport, now to me it looks like in your picture, the sensor is a single orange wire although I just looked again and there might be a black one with that orange wire. O well, heres what hasport says.
Its alittle blurry, but it waas orange single wire is the knock sensor.
[Modified by 90blackcrx, 3:22 PM 1/1/2003]
Old Jan 1, 2003 | 12:40 AM
Ham'ed Hatch
Guest
Posts: n/a
i have the same extra plug on my DX harness after i did my swap.
i guess you dont' need it. i've been told that by HASport and i've never had any problems.
gunnerman
12
Oct 24, 2007 09:40 AM
aznjay510
Jul 8, 2007 04:50 PM
batzcivic
Apr 27, 2007 05:29 PM
Boarderx192
Feb 26, 2006 08:32 AM
typhoon
Jan 6, 2005 01:10 AM
