d15b1 vs. d15b2
both are dpfi, b2 has more hp, difference that i know for sure are the restrictor plate under the t/b on the b1 and the b1 had a weaker cam. not sure if the ecm had a different program.
Guest
Posts: n/a
NON 88 d15b1 and all d15b2 = 9.2:1 c/r
slight difference in cam
header
intake manifold
d15b1 has a restrictorplate in the tb only allowing for 1/3 air flow of the tbody. removing it may make the motor lean out. im not sure about this... you only have 2 injectors
88 d15b1 had 9.6:1 c/r stock. same im and header as the other d15b1's w/ the restrictor plate.
header
intake manifold
lsvtec_hatchback
May 15, 2012 05:18 AM
turboblack2door
Nov 26, 2008 06:39 AM
user 98292739
Mar 6, 2005 05:48 PM
