Am i going too big with the turbo?
I am going with a .60 A/R housing 60 trim wheel and the turbine is a .82 A/R housing it is a T3/T04E.
Is that some thing that is going to be hard to spool, by the way i am looking on getting 500+ whp on race fuel and drive it on the the street too once in a while.
Is that too be too big? If so what should i go with this is going onto a 1995 gsr integra
that sounds like a pretty good turbo to go with, you might want to look into a stage 3 or 5 wheel though. on a b18c1 it shouldnt be THAT laggy... talk to the guys at http://www.cheapturbo.com, they know their stuff
that is where i might be getting it from and i also need a manifold for it i only have the log style drag manifold.
What manifold should i go with also?
inline pro or http://www.full-race.com manifold
with that turbo and a manigold from full race should do the job?
i am building my bottom end also, what do you think about that it is all going to be sleeved and all the other goodies.
in that case what should i be pushing about when all done and over?
I think that you should research and read up about everything before you start buying. Planning will save you a lot of money, believe me. You say that you want 500+ hp but dont expect to just slap it all together and get that kind of power out of your first application. Dont rush into things. Good luck.
That turbo will support 500whp, and probably a bit more. You should see full boost around 5500 rpm. The turbo is not the only thing that makes power though. If you are running race gas, just run more timing to make the power. The 60 trim compressor maps match b18c engines very well, especially at higher boost levels. The turbo should be efficient till around 24-25psi.
As for the motor work i am going with a built bottom end with larger valves and full porting work done
and the help of the s200 or the AEM dont know witch to get yet still have time
what about a t04s 60-1 w/ .82 a/r or a t62-1 w big shaft? do you think they will be too big for the street? will either of those turbos be too laggy? i want a new turbo for a 2.0l b16 and i dont want to go with some thing too big but i want a BIG turbo. any suggestions?
The 60-1 and 62-1 t4 variety are way to big for the street. You can support 500+whp with a t3/t4 and still get decent spool up. I dont understand why you would want something even more laggier? You cannot use 350whp+ on the street anyways, its just all wheel spin. So unless you are running some decent sized slicks to drive everyday, all that power is just a waste. My choice on a 2.0 engine would be t3/t4 60 trim, .82a/r or 60-1 t3/.63a/r. Both will make full boost about the same time, but the 60-1 will support a bit more horsepower. But in the same token the 60 trim compressor map is better suited to the 2.0 engine efficiency wise than the 60-1 compressor map.
[Modified by boosted hybrid, 2:43 PM 1/2/2003]
What is your spool up time? What engine do you have in your civic? Curious since i could barely spool up my 60-1 .63a/r with my b16a i had awhile back.
Smarter than you
I run the t3/t4 62-1 w/ .82a/r on the street. you ever see a civic run top end?? it all depends on what you are looking to do with your car. i like to run high mph roll.
That turbo will easily support the power you are looking for. Great choice!
to you you did steer me in the right direction from the begining
sould i go with the full-race manifold or is there any better?
It is going to be in an integra i am just wondering about the room for the waste gate
How do you get something or answers from full-race i dont even see a email.
And i am wondering on how much there manifolds are going for too?
Does anyone else have any prices for there manifolds?
i am just tring to fugure out if i am going to get it from TurbochargedSER or http://www.cheapturbo.com
becouse i want to get the coating and the hone and the 360 degree bearings
and with http://www.cheapturbo.com they have a stg 5 upgrade does that mean it is going to be a turbonetics?
that is what is see on ser20preformence.com that it is going to be a turbonetics turbo
whitch should i go with?
