vtec changeover???
Old Dec 30, 2002 | 05:32 PM
romeirome1's Avatar
Default vtec changeover???
is it better to have vtec kick in @ a lower or higher rpm. or does it depend on how u build your motor
Old Dec 30, 2002 | 05:36 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: vtec changeover??? (romeirome1)
Dyno runs are the only TRUE way to tell if your VTEC needs to go higher or lower.
Old Dec 30, 2002 | 06:39 PM
eg6ajk's Avatar
Default Re: vtec changeover??? (B18C-EJ1)
very true statments... yes the motor and its stage of modification plays an important role. other issues type of driving (drag, circuit, daily driving)
on a stock motors best to keep it stock.
b16a with mild bolt ons is fine with 4800-5500rpm vtec
b16a with cams and more bolt ons usually will be best at 5000-5800rpm
b18c1 gsr with cams and bolt ons but stock intake = 4800-5000rpm
b18c1 gsr with skunk2, cams and bolt ons = 5000-5400rpm
ITR motor stock = 5200-5500rpm
ITR fully built with JUN/TOda/skunk2 (2 or 3 stage) cams = 5800-6400rpm
H22A with some mild bolt ons 4800-5200rpm
d16z6/y8 with mild build up = 4400-4800rpm
d16z6/y8 with wild cam = 4900-5200rpm
these figures are from many tests and dynos I have witness
Old Dec 30, 2002 | 08:43 PM
TEAMGENDAI's Avatar
Depends on motor set up and go to the dyno!!
Old Jan 8, 2003 | 07:36 PM
romeirome1's Avatar
thanx for the info
allmotorgsr98
48
Apr 26, 2013 04:05 PM
AllmotorGSReg
Jul 22, 2009 06:37 AM
JFG Kevin
Aug 29, 2004 08:42 AM
tommyblaze
Dec 1, 2003 08:17 AM
KevronsEG
Apr 29, 2003 10:39 PM
