Jegs Fuel pressure gauge
Does anyone know what size the threads are on the guage? The website says "1/8'' NPT male inlets." Now is that talking about the thread or the little hole in the center of the end? Im confused and helpless!! Help!
you also need a Mr Gasket 3/8" fuel line adapter.
Part #720-2975. I installed mine on the rubber line between the filter and fuel rail. Pick a spot, cut the rubber line, install adapter, install gauge.
I used a Moroso part and had to grind down the barbs a little to slip the fuel line over. Mine has been that way for over 4 years, never a leak.
