Oil Gaskets?(Labor)
Normaly How much is labor to install oil gaskets all 3 of them? they like $.25-$1 so how much is that labor like an round figure? Cause i have a leak so it has to be my gaskets. Or does anybody know how to do this? What is involed with this operation?
And what seals?
Oil plug
Oil Pan
Oil Pump
Seals i do now know of........
are u talking about this
http://www.expressautoparts.com/impo...TOKEN=91035524
I was thinking about getting this set right here what do u think or do i even know what i am talking about?
Where would i get a cheap Valve cover gasket set.........or head cover gasket set from............i talk to the Honda they say labor for that job should be no more then $150-$200..............
The valve cover gasket is like 12 bucks. The little o-rings for the spark plug tubes are about 3 bucks a piece if I remember correctly. They are so easy to change. Just unbolt the bolts holding the valve cover on, replace gasket, bolt back on. Some use a liquid (black rtv silicone?) around the corners to ensure there are no leaks. Do this one yourself...
the oil pan gasket should be equally easy to do. drain the oil unscrew the bolts holding the oil pan on and replace the gasket and then reverse the procedure. Easy as can be
EGgoJDM
Dec 1, 2009 12:05 PM
