Wiring help
From: the asshole of america..., upstate new york, USA
oh...if your just doing a simple hard wire like that and you dont want to cut into anything just plug the 12 volt wire into the fusebox and put ground to ground.
just find a fuse that has power with just the ignition on - or power all the time if you want to leave your phone to charge with the car on or off. (cant think of what they are labeled without looking)
take the fuse out and check for power on both sides of the fuse holder...plug your wire into the side that doesnt have power...that way if something happens to it the fuse will blow.
when fuse unplugged
--12v ^------^ no power
-------- __-- __
12v in [--]__[-] power out
--------[______]
plug into the power out half
(pictures are a pain in the *** to make)
actually just fold the wire over the edge of the fuse and shove it back into place
note: the wire has to be somewhat thin for this to work...and i just suggest this if you have a virgin harness and dont want to start hacking into it.
[Modified by fastcrxsi90, 12:16 PM 12/30/2002]
when fuse unplugged
-------- __-- __
--------[______]
Thanks, but my harness has already been hacked into. I'm just looking for a safe wire to tap into w/o messing something serious up. I might just try that suggestion though.
do you still have the cig lighter?? Tap into those 2 wires or if you want a constant + there is a white/blue wire in the dash that is constant + and use the black wire for the -
loki2323
Audio / Security / Video
Dec 29, 2005 09:02 AM
mugenracer
Apr 3, 2004 05:50 PM
