spring length...4" vs 6" vs 8"
Old Dec 30, 2002 | 05:51 AM
87accord's Avatar
Default spring length...4" vs 6" vs 8"
I recently put a skunk2 90-97 accord coilover kit on my 87 accord hatchback. I have koni red struts in the front and tokico premium blue struts in the rear.
the 90-97 skunk2 kit has four 8" 8kg/mm springs (about 440lb/inch), the rear setup allows the drop range I was looking for, but when fully adjusted down the front drop is less than I want by about 1" to 1 1/2". I need to get a 6" or 4". Skunk2 sells a 6" 8kg/mm , landrum has a 4" 400lb/inch, hypercoil has a 4" 400lb/inch. I've got enough sleeve adjustment to use any of them but I'm wondering about the differences between a 4" and 6" coil. Ground Control has a 6" 450lb/inch. Another factor is that I've got 440lb/inch on the rear. Looking for advice. Thanks.
south_sac_red_ek
18
Oct 9, 2008 07:16 PM
killerpenguin21
Suspension & Brakes
18
Sep 29, 2006 09:37 AM
thatbluecrx
28
Aug 9, 2005 08:47 AM
mr_mbuna
Aug 9, 2003 09:45 PM
m0t0rhead
Nov 24, 2002 10:24 PM
