n2o timing?
Old Dec 29, 2002 | 09:03 PM
ratherbewalking's Avatar
Default n2o timing?
ive done a search, and got some answers to my questions. im wondering if you need to do anything special when doing a direct port n2o setup.
Old Dec 30, 2002 | 03:48 AM
Jeff C's Avatar
Default Re: n2o timing? (ratherbewalking)
I think its 1 degree of retard per 25 shot. I dont think it matters whether the kit is dp or single fogger.
Mine is retarded x4.
Old Dec 30, 2002 | 05:28 AM
337 GTI 1.8t's Avatar
...depends on the plugs you are running, what fuel, and what size shot. remember, retarding your ignition timing makes things hotter, not as hot as detonation, but finding that medium ground is important. Also, it is a common mistake to retard your timing and then add nitrous/fuel, when in actuality, a little more advance with less juice/fuel would make more power with less heat. Tuning.
[Modified by GTI 1.8t, 2:29 PM 12/30/2002]
Old Dec 30, 2002 | 06:20 AM
Default Re: n2o timing? (GTI 1.8t)
thanks for the responses, what kind of tuning ? (dyno?)
Old Dec 30, 2002 | 06:47 AM
Desslok's Avatar
He probably means dyno with air/fuel reading.
Old Dec 30, 2002 | 06:57 AM
By tuning I mean finding the best combination of adjustable variables to keep the motor efficient as possible and together. Make sure all your parts and setting work together for this. Dyno-ing the car with a wideband, reading the plugs, making 1/4 mile passes and comparing slips, factoring in manufacturers/reputable builder-tuner advice...etc.
[Modified by GTI 1.8t, 3:58 PM 12/30/2002]
Old Dec 30, 2002 | 08:20 AM
thanks!
TB123
Engine Management and Tuning
Dec 30, 2013 08:34 PM
Mike Lowwryyy
Jul 12, 2012 08:50 AM
dominate9
Dec 4, 2003 05:05 AM
tc
Sep 22, 2003 06:10 AM
TypeR1558
Feb 11, 2002 04:06 PM
