My turbo shopping list, did I miss anything?
Old Dec 29, 2002 | 07:05 PM
BlueShadow's Avatar
Default My turbo shopping list, did I miss anything?
Hey everybody,
I just got done writing up a list off all the stuff I'm gonna be getting in the following weeks.
For now my plans are to run 7 PSI and make ~250-275 WHP on 91 octane, and stock internals (for now). Shortly after all the turbo stuff is installed I want to get a Quaife and an ACT HD PP and 6 puck disc.
But to run 7 PSI initially I believe that this is all the stuff I will need. The only things I need help selecting is the ignition system and what vacuum lines to get and where to get them.
I have about $2000-$2500 to get the rest of the parts, I'm thinking that should be enough to cover the parts and labor (to fab up a new DP & exhaust).
EDIT: changed my budget, because now I have a spare short block coming my way
WOOHOO!!!
<u>STUFF I HAVE NOW:</u>
TO4E 60"
T3 .63 A/R STAGE 2
MANIFOLD
PIPING
INTERCOOLER
DOWNPIPE (need to make a new one)
DELTAGATE MARK 2 (not using it)
<u>STUFF I WILL BE BUYING: </u>
AEM EMS
GM solenoid part # 1997152
A/C compressor clutch socket Part # 85145
FJO wideband O2
DSM 450cc's and resistor box
Tapped oilpan
1/8" NPT to 1/8" BSPT Autometer Part #2269
Braided SS Hose 3ft. #3 3/16" ID Fittings Autometer Part #3234
-3 AN oil feed line
1/2" NPT to -10 AN fitting
-10 AN SS braided hose with two -10 AN auto fit ends
-10 AN weld fitting
Garrett T-3 Turbine Housing Discharge Flange & Gasket
2 1/2" Down Pipe (First Bend)
2.5" to 3" reducer
3" Braid Covered Flex Pipe
two 3" flanges & one gasket (3 hole)
3" Catalytic Convertor
one 3" flange & one gasket (3 hole)
3" cat-back (magnaflow muffler)
NGK 4291 (ZFR6F-11) spark plugs gapped at 40
MSD 6AL
TIAL 35mm WG (5 psi spring)
Apexi Twin Chamber BOV (universal)
5 silicone hose reducers
7 T-bolt clamps
Greddy oil catch can
AEM Tru Time cam gears
Autometer 2 guage pod
two Autometer universal guage cups
Autometer 20 PSI boost guage (mechanical)
Autometer oil pressure guage (electrical)
Autometer EGT guage
Autometer A/F guage (temporary, until I get the FJO)
[Modified by BlueShadow, 8:27 PM 12/29/2002]
[Modified by BlueShadow, 3:34 PM 12/30/2002]
Old Dec 29, 2002 | 08:18 PM
kb798's Avatar
Default Re: My turbo shopping list, did I miss anything? (BlueShadow)
yea you forgot one thing. u forgot to give it to me hehe jk
Old Dec 29, 2002 | 11:18 PM
kidaniel's Avatar
From what I have been hearing, Skunk 2's cam gears are ligher. They also have more bolts so they have less chance of slipping. nice set up...wish i could afford thatr about now
Old Dec 30, 2002 | 12:21 AM
satan_srv's Avatar
Default Re: My turbo shopping list, did I miss anything? (kidaniel)
I made a post about it....yes they are lighter...
Old Dec 30, 2002 | 02:33 PM
BlueShadow's Avatar
Default Re: My turbo shopping list, did I miss anything? (satan_srv)
Thanks for the info about the cam gears guys.
For anyone else that cares, my budget just went down to $2000-$2500, because now I am also buying a spare bottom end from one of my fellow PO.com members.
So do you guys think I will still be able to buy all that stuff for $2000-$2500?
TIA
Old Dec 30, 2002 | 03:34 PM
ziggity's Avatar
i have been reading on PO.com about as long as you have and i just so happen bought a custom kit from the co owner of this board for my prelude the same time you bought yours and i think the only major thing you are forgetting is a clutch cause you can kiss your stock one goodbye i got myself a fidanza fly and action stage 2ks from a groupbuy here on h-t if you want email me and ill email you a spreadsheet of all the **** i have bought and stuff i have yet to get to be finished
edit i just noticed the clutch in the top line sorry
[Modified by ziggity, 7:35 PM 12/30/2002]
Old Dec 30, 2002 | 04:05 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: My turbo shopping list, did I miss anything? (ziggity)
item list looks good.... but you should look into the techedge wideband unit, it's a lot cheaper.... i ordered mine like 2 weeks agon, and got it 2 days ago, it's a nice system, and will save you some cash to put towrds something else
Old Dec 30, 2002 | 05:06 PM
BlueShadow's Avatar
ziggity,
Did you know that I tried to outbid you for Mike's turbo kit? hehehe
I practically begged him to sell it to me, I offered to pay him $2500-$2700 for his kit, and I offered to pic it up from him. I can say this without even seeing his kit that you got a really got deal. I just wish I had offered to buy his kit 2 days sooner...so let me just say you had better not back out of your turbo project otherwise I'll be pretty upset
BTW what spreadsheet program are you running? I would be interested in seeing your part list as well. You should also post it on here, that way you, me and everybody else can compare them.
Boost97Lude,
Isn't there a backlog of people trying to order the techedge? that was the reason I put FJO down. I know of a place where I can get an FJO for about $750, but I'm not getting it right away.
right now I need to start shopping around for the best price for my shopping list. I'm gonna be ordering my AEM EMS from B18Bturbo in the morning, then I'm also ordering some of the miscellaneous parts (injectors, flanges, BOV, etc).
right now here is my timeline for my turbo project:
@ Feb 01-Feb 15 completed buying parts, fabbing up misc. parts, install turbo, get it tuned on a dyno
@ Apr 15-Apr 30 install ACT HD & 6 puck, install Quaife LSD, Install FJO(or tech-edge)
@ Jun 1-Jun 15 completed building spare block, swap out bottom end, turn up the boost
[Modified by BlueShadow, 6:09 PM 12/30/2002]
Old Dec 30, 2002 | 06:04 PM
Boostless97Lude
Guest
Posts: n/a
like i said..... i bought the assembled techedge, and i recieved it about 2 weeks after i ordered it, i got the v1.5, whether that makes a difference or not, i paid like $300 for the unit, and another $250 for the O2.... i bought mine for the autotune feature on the AEM EMS
Old Dec 30, 2002 | 06:35 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: My turbo shopping list, did I miss anything? (Boosted97Lude)
also... what kind of autometer universal cups are you buying, and where are you mounting them? i kinda need a few more guages myself
Old Dec 30, 2002 | 07:15 PM
Boostless97Lude
Guest
Posts: n/a
oh, and why do you need an EGT guage?
Old Dec 30, 2002 | 08:31 PM
ziggity's Avatar
- T3/T04E turbo. 54 trim compressor housing. .63 turbine housing w/ stage 3 wheel.
- Drag gen 4 Manifold
- Drag gen 2 turbo kit piping for Prelude.
- Drag gen 2 intercooler.
- 2.5" custom downpipe w/ flex pipe. Bolts to cat back exhaust.
- Greddy BOV
- Tial Wastegate 35MM.
- Custom wastegate dump tube. Clears Drag 4 manifold.
- Vortech FMU.
- Inline fuel pump.
- J&S Safeguard w/ dual monitor.
- Greddy Electronic Boost Gauge White. 52mm. Like new. Includes MAP sensor.
- Greddy Electronic EGT Gauge White. 52mm. Like new. Includes probe.
- Gauge pod. Holds two gauges.
- Premodified black A/B pillar cover for gauge pod. So you don't have to
destroy your stock one.
- HKS Turbo Timer.
- Missing Link MAP Bypass Valve.
- Summit Battery Relocation Kit.
- Oil feed kit from Drag Gen 2 turbo. Stainless -3 line. Includes brass tee
for oil pressure switch and all fittings to connect to turbo.
- Oil return line and fittings. Includes adapter that bolts to the bottom of
the turbo, and both -10 AN earls hose ends. Stainless line.
H22a4 oil pan with -10 AN fitting to connect oil return. Save your stock pan.
Pretapped brake booster hose to provide vacuum for wastegate.
Driver side accessory garnish modified to fit turbo timer.
- Silicon vacuum lines and tees for wastegate, bov, boost gauge sensor, etc.
Stage 2 KS action clutch
Fidanza flywheel
Skunk II cam gears
Apex AVC-R
cometic or inlinepro head gasket
new tires well very soon
brakes also will need these
timing belt kit its about time eh
Hondata s200
P28 ECU
Oil Cooler/ Relocator
Oil Catch Can
NGK Plug wires
NGK copper cold plugs
resistor box
injector clips
clean injectors
head studs
transmission rebuild i have a shitty grinding problem
OBD2 to OBD1 harness
tuning from vaportrai
hondata IM gasket
ES motor mounts
rear main seal
give or take a few of these things and i think ill be ok any suggestions for me besides a wideband 02 i know it is nice but not ready quite yet
Old Dec 31, 2002 | 02:21 AM
BlueShadow's Avatar
'm getting , my guages, podsand cups from http://www.optauto.com and I plan on mounting them on the right side of my drivers side dash, close to the clock.
http://www.optauto.com/webstore/prod...=yes&dept=1533
Old Dec 31, 2002 | 05:23 AM
Boostless97Lude
Guest
Posts: n/a
hey ziggity, um... why are you using a P28 ECU, shouldn't you be using a P72?
Old Dec 31, 2002 | 03:53 PM
ziggity's Avatar
the p28 is much cheaper and basically if i want to use the secondary butterflies i can get a rpm window switch and i have a J&S so the lack of a knock sensor in the P28 doesnt bother me but i am not convinced i will see significant gains by using a P72 over a P28
Old Dec 31, 2002 | 06:28 PM
Boostless97Lude
Guest
Posts: n/a
well, if you decide you want a P72, i have one, but with hondata, you can elminate the knock sensor anyways
DC2teggY
Jun 4, 2009 05:23 AM
shervin
Apr 14, 2005 09:44 PM
5thgencivic
Jan 12, 2004 07:17 PM
