200 +hp rsx's
2 members at clubrsx have gone over the 200whp w/o leaving NA...
http://forums.clubrsx.com/showthread...threadid=58974 did 225.3hp / 158.9tq
http://forums.clubrsx.com/showthread...threadid=58896 did 202.9whp
Fair observation, but by removing the wheels/tyres you have one less variable. I read the thread and he has used the same dynapack to measure changes from start to finish. I don't think he his trying to get the highest numbers around. Just wants an accurate measure for each mod.
He baselined about 175HP on the dynapack and has measured each mod along the way, ending with 225HP. Its the accurate measurement of the 50HP that matters, not whether the final amount is 150HP or 250HP. Seems you can get about 50whp out of the RSX with bolt-on's/ECU.
Very well put mpd076. Even an innaccurate dyno is a good tool to determine if the mods you performed did their job. However, the dyno must be precise.
Accuracy and precision (repeatability) are two different things.
-kenji
-kenji
Its a dynapack so its attached to the front hubs, wheels removed. Probably didn't change the graph title.
and that will explain why he makes great power, no tires to spin.
that's just an assine statement.....you must make mad hps for your tires to spin on a dyno....the dynapak does not make more hps than a dynojet....typically 17% less
have you gone mad? do you even know what a dynapack is? they typically measure about 10hp higher than dynojet pulls. feel free to call shawn church auto test in torrance, ca for a reference.
So before you go questioning people whether if they're "mad", crazy, or whatever, and before you go answering people's post on hearsay, make sure you've actually worked with the equipment...that'll probably be more help to people!
CheEsEsTeAk168
Apr 1, 2003 12:16 AM
