ITR Powered 1991 si hatch
Old Dec 29, 2002 | 02:34 PM
STHPERFORMANCE's Avatar
Default ITR Powered 1991 si hatch
Just curious as if this is all i would need to get a 2000 ITR motor up and running in my 1991 si hatch......
- Obd0 Distributor
- Obd0 Ecu (pr3 - pr0)
- I have a hondata stage 3 for tuning.
What else would be needed?
Thanks
Old Dec 29, 2002 | 08:40 PM
Superhatch's Avatar
Default Re: ITR Powered 1991 si hatch (sirk)
Im sure you can search for any obd2 swap info.
infact....
https://honda-tech.com/zerothread?id=279032
https://honda-tech.com/zerothread?id=320118
o.k. not a ton..but.
1. Are you doing a hydro tranny conversion, or using a ys1?
2. Are you going to do a full harness conversion?
-Jake
Old Dec 30, 2002 | 12:49 AM
Jaker's Avatar
Default Re: ITR Powered 1991 si hatch (Outkast)
Don't need OBD0 injectors. Its all in the wiring. If you're going to the trouble of putting in the ITR motor, might as well go OBD1. You'll save yourself alot of tuning hassles with the Hondata by going OBD1. Also, converting a P28 or a P06 for Hondata is going to be pretty cheap, and you'll already have the distributor, injectors, and O2 sensor.
[Modified by Jaker, 1:50 AM 12/30/2002]
hondachris1994
Mar 10, 2009 07:21 AM
joshfish79
Sep 23, 2007 12:53 PM
1FSTNDN
Nov 7, 2005 02:44 PM
crx-treme
Sep 27, 2005 02:58 PM
C4wrx
Aug 9, 2002 12:00 AM
