stock fuel pressure
what is the stock fuel pressure set at? two questions tho i ask this because i got a new adj fpr today but its not the kind that bolts to the stock rail like the AEM or B&M. it has its own gauge which i tested and the gauge does work. it has two barbed fittings almost like an FMU but im wondering where do the lines hook up to? this isnt the one i have but the fitting locations and style are very similar
it almost looks like the line going up to the fuel filter connects to the fpr but that wouldnt make any sense cuz then how would the fuel get filtered? if that factory regulator stayed in place where would the vacuum line go?
[Modified by JeremyL, 2:34 PM 12/29/2002]
well that aint the one i got but the one i did get was like $70 shipped and the damn box it came in was all in jap and it didnt come with any instructions
lol ok well how do i do that? seriously i looked at the car and the regulator and it just didnt make any sense, i must just not be seeing something right
in the case of an FMU you would leave the stock reg in and cut the fuel line from reg to the main return line of the cars hard line
so does that mean i have to cut the line and put a T fitting in the line that comes up to the stock regulator?
that would solve the issue of that barb/line but what about the other one?
well i did just replace my fuel filter and the banjo bolt did have a threaded top with another bolt that went thru it so ill try that idea later today, hopefully the gauge will fit
if the one you have doesnt fit ... i have the B&M FP gauge it was like $20 or something .. it fits perfect
boostinscrappy
Honda S2000
Jun 30, 2013 06:05 PM
nd94cx
Sep 16, 2004 07:03 AM
