Engine Dampner Kit
Does anyone have any info on J's Racing Engine Dampner Kit? I remember a pic of one installed awhile back. If my memory is correct it bolts up to the drivers side engine mount.
According to A&J racing - they don't fit LHD cars properly.
Use stiffer motor mounts instead - probably cheaper too.
This one?
https://honda-tech.com/zerothread?id=359126
[edit] Never mind. I can't read. [/edit]
[Modified by Splat, 6:17 PM 12/29/2002]
why would our torqueless(sp) engines need one of these??
Have you ever experienced the wheels skip and jump on the pavement under WOT in 1st gear?
Have you ever experienced sluggish response due to the engine not responding as immediate as it should when you hit the accelerator?
.......apparently not.....
Have you ever put your car on a dyno and watched the engine move?
i think a little less tone would be ok, this is a discussion and not a match as to how thinks they know more.
apologies for coming off harsh...
share what you have in mind...
all I do know is the DC2 app. is not gonna work unless the piece you have designed is intended for the 6th gen hatch...or maybe something better for the DC2?
turbotime
Aug 10, 2006 03:10 PM
Tyson
13
Dec 24, 2003 10:25 PM
Drinker
