OMG,Only one quart came out after oil change!
Old Dec 29, 2002 | 10:59 AM
vtechatch's Avatar
Default OMG,Only one quart came out after oil change!
I have been useing my car for work which entails driving 250 miles a day.
I have a 2000 B16A2 motor and yesterday I did an oil change and only enough oil to fill one empty quart bottle came out.
I did an oil change about 1 and a half months ago,Maybe 7000 miles or so ago.
My Vtec has not been working properly for a while now.
I have NEVER used synthetic oil until yesterday when I used Mobil 1.
I checked my oil 3 weeks ago and no oil registered on the dipstick so I added a qt
I checked it a week ago and no oil still registered on the dipstick so I added another qt.
Where in the world did 5 of those 6 quarts go.How is my car not blowing up with all these miles and no oil?
My theory is that the conventional oil is just getting burned up in my high revving motor and maybe thats why most people use synthetic.I hope.
The motor has 40,000 miles total.
Im perplexed here,any and all feedback will be appreciated.
Thanks
Dan
Old Dec 29, 2002 | 11:04 AM
rbf351's Avatar
Default Re: OMG,Only one quart came out after oil change! (vtechatch)
can be a few things
bad rings, bad valve seals, or just a leak somewhere
u blowing any smoke?
Old Dec 29, 2002 | 11:20 AM
FredoSP's Avatar
do a compression test, just to be sure. If you need help on how to do it, let me know. 40k huh, usually our motors are healthy around those miles
vtechatch's Avatar
Default Re: OMG,Only one quart came out after oil change! (rbf351)
No smoke,Thats why Im confused,Where in the world is all that oil going?
Old Dec 29, 2002 | 11:22 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
is it better to use synthetic in our b-series?
Old Dec 29, 2002 | 11:46 AM
Chiovnidca's Avatar
It's either leaking or getting burned. Checking your oil at every gas fill up is a good idea, but it's probably too late now. Running an engine on one quart of oil causes alot of damage. BTW, burning one quart of oil every thousand miles is considered acceptable.
Old Dec 29, 2002 | 11:50 AM
vtechatch's Avatar
Default Re: OMG,Only one quart came out after oil change! (Chiovnidca)
Oh ,In that case I have burned 5 quarts in 7000 miles so that is acceptable.
The car still runs smooth as new with no noise.
Dan
Old Dec 29, 2002 | 11:53 AM
Chiovnidca's Avatar
Dan
Start checking your oil level and topping it off when it is low.
Old Dec 29, 2002 | 12:16 PM
obd2gsr's Avatar
Default Re: OMG,Only one quart came out after oil change! (dLo GSR)
as long as you change your oil at the proper intervals, shouldn't matter what kind of oil you're using, provided it's not like vegatable oil
Old Dec 29, 2002 | 01:55 PM
Zubz's Avatar
Default Re: OMG,Only one quart came out after oil change! (obd2gsr)
i've never heard that burning one quart of oil every 1K miles is acceptable. who says that?
FredoSP's Avatar
Default Re: OMG,Only one quart came out after oil change! (FredoSP)
Dude.. do a compression test, maybe ur rings are shot.
Old Dec 29, 2002 | 02:04 PM
Mighty's Avatar
Default Re: OMG,Only one quart came out after oil change! (ZubzSi)
1 quart per 1000 miles is a general rule for cars. If you had a car thats under warranty and you tried to get the engine replaced under warranty because it burns too much oil, but if it burns less than one quart per 1000 miles the dealer will most likely tell you tough luck. Or if you had a car with a lot of miles on it and you were thinking of rebuilding it becuase it burned oil, most people will tell you that as long as it burns less than 1 quart per 1000 miles its ok.
Now a Honda with only 40k burning that much oil is weird. Obviously check for leaks. Are you smoking real bad at start up and not noticing it? Smoking at start up indicates bad valve seals. Also, some cars are known to burn a lot more oil at high RPMs. Maybe you just have one of those cars?
Obviously, running with just 1 quart of oil is not recommended. But it doesnt necessarily gaurantee engine damage. If youre ambitious pull the oil pan and clean it and check for metal particles.
[Modified by Mighty, 11:08 PM 12/29/2002]
Old Dec 29, 2002 | 02:26 PM
Chiovnidca's Avatar
Honda.
Old Dec 29, 2002 | 04:11 PM
TREVER's Avatar
Techline has told me 1000 for a qaurt too, but thats bullshit. Thats just honda backing out of a warranty repair . 3k to a qaurt is pushing it for any stock honda motor.
For this case i'll bet the damage is done. Every one should check there oil level every fill up. Do a compression check. 7k without even checking your oil and now you pay
Old Dec 29, 2002 | 04:26 PM
Norcalstoppy's Avatar
Default Re: OMG,Only one quart came out after oil change! (TREVER)
6qts????
I thought it was 4 qts?
Jay Kim
Old Dec 30, 2002 | 10:31 PM
Ek-CoolGuy's Avatar
damn, what a waste of oil.
k3ntegra
May 19, 2015 05:10 PM
Tong.Y
32
May 11, 2011 09:18 AM
HondaGSX
Honda Civic (2006 - 2015)
14
Jun 20, 2006 06:22 AM
purplevtec
Nov 21, 2004 01:01 PM
NewR
Apr 28, 2002 06:25 PM
